crescendo audio bc3500.1 mono are they any good
SAZ3000
BC3000
Need I say anything more?
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
The old 3k shared a board with the saz3k, but with the bc3500, Cresendo switched boards to what is a shared board with the AQ 3500. The bc3500 is rated 3850 at 13.8 and the AQ 3500.1 is 4300 at 14.4. Our team has used both the bc3500, the aq3500d and the aq 3500.1. Without turning this into a pissing match, all I will say is if an extra 100w or so matters to you, then pay 200$ more. If it doesnt, then go Cresendo. Cresendo is very stout below 1ohm, as is the AQ. The .5 warranty is no longer in effect for Cresendo cuz people were wiring 3ks at .5 on stock electrical and smoking amps and expecting a refund. Just because warranty is no longer implied, doesnt make the build any less stout...just means Navid is tired of replacing amps that same jack ass put on stock electrical.
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
^ yes because every AQ does exactly 4300w and every cresendo does exactly 3850w. My teammate was only clamping 21xx out of a 3500.1 at roughly 2.5ohm, the Cresendo at 2.5ohm isnt doing 1600w, as your post would lead people to believe
Team Flex Issues
Low tuning > God
