XS Power
12v batteries with 14 volt xspower batt?
I was wonderin if i can keep 1 12.6 volt batt and add a 14volt batt(xs power) in parallel togethor ? Will this over charge my 12 v batt. I know my alt is running at 14.4 v and i plan on adding a diode to bump my voltage up to 14.8 ish on the alt. im just wondering if it will overcharge and damage my 12 v agm battery
Orion 2500D , 2-10" alpine type X. Custom enclosure,
Alpine amp for mids and highs.
Working on a center channel ATM
Before you touch anything please read into the way this works.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
First off, im only trying to help not trying to offend...
14.x isn't high enough to charge a 14v battery. If you didn't know that much, you shouldn't try to mess with anything 14V until you do alot of research as it isn't safe to do so. By research I mean search the forums, find Tony Candela's YouTube channel, he also has some books out you could learn alot from. That's a good start anyway.
Alright thanks! Im just wondering what i can do to help my voltage drop ... Id like to keep it at 14v-13.8. While playing . I had a orion 2500d that fried the mosfets because of voltage drop. The amp was tunned with my oscilloscope. Any pointers to keep voltage up?
Alright . with the gm alt's does it make sence after i start my truck on a cold day it notice my batts lost charge so the voltage goes up to 14.8 to recharge my batteries. I dont have volt drop when it does that. Its like the rectifier in my alt goes to max. Then once the batts are charge or a normal day ill get volt drop on idle. I have a 253amp alt... The rectifyer should output amps when it needs it shouldnt ?
you burned up an orion 2500d with low voltage :shok:
I have no clue.. i have ran those amps since they came out and down into the low 9v rang and never burned one up due to low voltage.. but then again you never know.
disregard my message i was never here
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
Hahha sadly yes i did . It blew and the volume wasent even on when it did. Sad to say... But i guess back to the cheap low line hifonics i go! Im going tonight to get my alt load tested and such its like 2 years old
If the volume was turned all the way down when it blew, then you may have had a different issue.
Though low voltage can be a major issue.
You will always have voltage drop no matter what.
It's best to get the battery quantity and size that can supply your amps with more than what they need at full power. Run it from an alternator that is capable of charging the batts with a bit of extra amperage for overhead.
Adding a 14v batt will not work. There is no quick fix. All batts connected in the same charging system must be of the same voltage, and the same type. Switching to a 14V system is a big job and requires your alternator to charge at over 16V.
Stick with a 12V system and get your batts and alternator up to par.
What batts do you have now? What wires? Give details of your electrical system.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
  • Who's Online   0 Members, 0 Anonymous, 1023 Guests (See full list)
