im gonna be running 6 sa8s, looking to get as closest to a 1 ohm possible
what coils do i need to run 1 ohm? d4 or d2 to get me .5-1 ohm?
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
dual 4s i believe will get you to 1.33. Ive been up since 3 am though so I could be off.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Dual 4s can get u a 1.3 and dual 2s can get u a .7
Ninja'd by n8 lol
Edited by jg23
2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0
Build Log
UBL My YouTube channel
lol ok thanks ill wait for more replies, id prefer to fall under 1 ohm, than above just for rise reasons and shit
Team Sundown Audio
Go with da dual 2s then bro for that .7 final load. I got smart when I ordered my XLs and went with the dual .7s, wired each sub in series for 1.4 each and ran them to the amp for a final load of .7.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Go to the12volt.com and look up the sub wiring diagrams with 3 subs at whatever ohm you think and then parallel/series each set of 3 together. That's how I did my 6 10s. With dual 4s I wired each set to 6 ohms and then parallel to 3 ohms
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 1035 Guests (See full list)
