Soundstream SPLX BREAKING AGAIN
langsdon2
about clipping. isnt it ok for the subs to clip softly. not a full clip. but just a quickie :) assuming that the subs are not overpowered they should be fine, atleast mine are :)
a clipped signal will move the subwoofer in a un natural motion. Imagine the motion being a smooth ripple like a ripple in the water, but if that signal turns violent, basically starts to lose its shape, square wave, etc, the subwoofer cone loses control, and can cause mechanical issues usually with the triple joint, leads, or coil over heating.
I do think it is possible for the plastic spacers to fail to clipping, if the coil is moving a lot further than the spider can move, and that triple joint that connects the spider to the coil is strong enough, then the spider landing is the next place to fail.
I personally seen that a few times when I did warranty repair, but what I seen more was triple joints broken, leads, and coils burned
Basically, the manufacturer would have to warranty these speakers, because a glue joint broke free- Manufacturing issue
If the coil was burned, and the glue joint was intact, well, that is more of a customer abuse issue
See what I'am getting at?
My earlier stated 100% sure about glue failure, has dropped to about 75% glue failure/manufacturer failure 25% customer abuse
Glue.
Have a spider being held down by clamps on one of my MA Audio HK 18's due to failed glue. Also, I can make them stinky on 1500w of clipped power.. at well below tuning that is. heh.
Hammerdown... 1%
Im not saying that i know it all. I am just saying that i know that it is not due to clipping. And yes everyone automatically assumed that i am throwing a clipped signal to my sub. I know my one buddy that runs the aq2200d and the aq 18 and it clips all the time and its totally fine. Im sorry for offending anyone i was just trying to get help on the subject. Everyone needs to chill out a little and stop taking everything so personal.
Bang em if you got em
no one is taking it personal, we just dont want to see you get your subs fixed, then turn around and blow them because you are clipping them. then come back here whining because they blew....
so we are trying to explain to you how the gain works, and how the dmm does not stop clipping...
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
I understand. I dno where to even go to get it scoped
well the new shipment came in friday and just for fun we decided to hook one of them up to an aq 2200d and burp it at 44 hz. It held perfectly no more probs. slamming right out of the box.
What kind of vehicle do you have?
Get your own, if you are concerned about getting the most out of your system and want to do it right save up and get this,
http://www.testextra.com/
Then watch videos in,
http://www.stevemeadedesigns.com/board/topic/44377-how-to-set-your-amp-gains-with-an-o-scope-easy/
There is a video on youtube that Steve shows to avoid clipping all the way from the headunit, and you work your way to your amps.
I've never understood why people say it works perfectly out the box new.
Well I would hope so. Usually if you have a faulty sub, it will let you know very quickly.
  • Who's Online   0 Members, 0 Anonymous, 14127 Guests (See full list)
