something i made for a customer and her jbl 12" sub. i wish i had taking more pictures, sorry
glued and screwed sides and bottom to the back and dry fitting the front baffle and port to make sure it looks right
painted the inside of port. i still need to cut the angles for the 45 piece inside the port
all done and ready for pick up
it turned out ok, well she was very happy and couldnt get over the flaired port. it sounded just like any other ported box that is "properly tuned".
if you live in the sacramento area and need a sub enclosure made let me know. heres a link to my website for more info
http://www.freewebs.com/idyllicenclosures916/
how many cuts, and lenght inbetween, does it take to get a perfect 90 degree angle?
11 cuts every 3/4 " on the table saw for 90 angle.
i didnt glass the kerfed part alot of wood glue
edit: 11 cuts 1/2" apart
Edited by Sinosic
but im sure for a smaller radial bend then u would make more cuts that are closer together...correct?
i likes me some audio stuff...
so when you do the cutting say its 3/4" wood you only cut like 1/2" through or how exactly does it work,read the tutorial on toxic bass but forgot
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
im wonderin that same thing
it loox so cool i wanna do one
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
make each of 11 cuts 1/2" apart. you should experiment with a piece of scrap mdf. 1/2 is not enough the cuts should be about 1/8" before cutting all the way through. be careful cause it very fragial.
  • Who's Online   0 Members, 0 Anonymous, 1841 Guests (See full list)
