Does adding a thick plexi glass wall effect in any to the box? Could you build a plexi box and have the same benefits as one out of mdf?
for the most part an enclosure is an enclosure be it plexi- mdf- steel
R.I.P!
(Nov-29-2009)
92 explorer
current build
If that's so why is mdf always used.
i'm tuned in cause i just had the same thought like 5 min ago lol.
2 12" memphis mojo mojo12d4
hifonics brutus bxi 2610D
1/0 power wire
4 gauge speaker wire
ddm tuning 8000k 35w hids
C&D technologies battery (100 ah)
custom box tuned to around 45hz(designed buy fritosaregood)
2010 kia forte koup
cause its good at what it does
and is cheaper then birch, plexi and steel and stronger then osb
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
If you wanna use plexi, you've got to buy thick plexi. Which gets expensive.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
true the one piece of plexi on my box cost $100. so if you wanted to build a box out of plexi your looking at about $600 for plexi its self
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
MDF is perfect its cheap, easy to cut, easy to put together and its a solid material, a pixieglass box would have to be really thick to work, cutting it would be a PITA N putting it together would take forever to pre-drill and screw everything together would suck not to mention the price on pixie. just my 2cents.
2-18" Fi Btls
2-RF T2500-1bd
box 14cu.ft after displacement tuned @ 32hz.
Socal Box Designer/builder
Buy used hockey rink glass, polish it up then cut pieces out and glue them together in layers to make it thick.
Relatively cheap, very tough.
Only problem is you have to be careful when gluing or you will get air bubbles between the layers.
Hammerdown... 1%
