uhoh_45 Posted March 26, 2011 Author Report Share Posted March 26, 2011 built my table today 2 x 2 x 1/8 steel with .25" top plate and it is strong as hell n weighs like 200+ pounds haha i'll get more pictures later R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
David Posted March 26, 2011 Report Share Posted March 26, 2011 Table looks good bro. Link to comment Share on other sites More sharing options...
sprkn_ranger Posted March 26, 2011 Report Share Posted March 26, 2011 Yea that looks real clean man! Good work. Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/ Link to comment Share on other sites More sharing options...
uhoh_45 Posted March 29, 2011 Author Report Share Posted March 29, 2011 more pics like promised R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
uhoh_45 Posted March 29, 2011 Author Report Share Posted March 29, 2011 R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
98crewcab Posted March 29, 2011 Report Share Posted March 29, 2011 damn nice welds homie!!!! 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk! Link to comment Share on other sites More sharing options...
uhoh_45 Posted March 29, 2011 Author Report Share Posted March 29, 2011 the sexy table ones were done in my brothers warm welding shop with his miller 240 volt welding super hot 26+ volts haha my little lincoln 140 cant reach its full potential because i only have 15 amp breaker and it needs a 20 (if anyone can point me in right direction to add fuse panel/20 amp breaker in garage it would be greatly appreciated) and welding the .25" steel plate it was to cold and welder didnt like it and kept spitting but it turned out decent enough im happy R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
uhoh_45 Posted March 30, 2011 Author Report Share Posted March 30, 2011 made some hooks for each corner then got some angle iron and made some 90's so i can weld things together or hold piece wood straight made 4 one for each corner R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
numatik Posted March 30, 2011 Report Share Posted March 30, 2011 sorry i checked this thread out wayyy late. table looks good brotha, i used to have one that size but it would always get in the way. mine didnt have casters, but two people could lift it easily and move it around. what im doing now is actually a .25 plate on my woodworking bench. thick is bestter cause you constantly tack to it and grind it out, but i think .25 will be just fine. welds look good too brotha! Gary 'Numatik' Eberle West Sacramento, California Vehicle build log (1) 'Aayla' Numatik's one and only, bodydropped pasted the doors Chevy S-20 Ext-Ext cab. This project ended after a horrible horrible motorcycle accident. There are so many mods it would fill an entire page in my sig. Check it out if you have A LOT of time to kill. http://www.stevemeadedesigns.com/board/topic/39785-numatiks-doored-s-20-bodydropped-on-doors-ext-ext-cab-10-subs-full-frame-build/?hl=%20numatik#39;s Vehicle build log (2) 'Snow White' Daily/showstopper 2004 Chevy Silverado Lays on 22s soon for 26s to run a beefy tire on 4s (4) 5gal tanks, (3)AZOB2 pumps, Slam digital stealth two speed valves with 16 solenoids, Slam SS bags all around, ART upper and lower arms, KP Components 6-link, KP Components watts link, Panther juice 6 22s, Spikes EVERYWHERE. 3,600WRMS total, (5) Kicker amps, (2) L7 15s under raised back seats, 15" screen molded to dash, 36 speakers total all Mb Quartz and Fosgate. Fiberglass console with removable face plates and arm rests, flushed speakers, lots of toggle switches, Playstation 2, rear view camera, Suede and leather seats, suede headliner, Dakota Digital air gauges, voltage gauges, and current draw gauges. (2) XS Power 4800 batteries, Whole truck is flat black and white and the ENTIRE truck is fully pin striped by TJ Pagano here in Sacramento. http://www.stevemeadedesigns.com/board/topic/123328-numatiks-bagged-2004-silverado/ "What doesn't kill you makes you stronger. I am proof" - Numatik Link to comment Share on other sites More sharing options...
uhoh_45 Posted March 30, 2011 Author Report Share Posted March 30, 2011 yeah my brother kept telling me a 4x4 table is a big table but i plan on getting rid of that ping ping table and placing table over in corner and with the casters i can roll it anywhere i had rolled it outside today in the sun and did some work out in sun it was nice haha. this bitch is decently heavy took 3 of us to unload it from brothers truck haha was a bitch as for top plate thickness i donno im hoping .25s good but i do have another 4x4' sheet of .25 i could double up and make a 1/2" plate R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
