what rms can a 3500d do at 0.7ohm
depends on what amp.. you didn't state what brand.. but seems like you're referring to sundown.. you're probably looking at around 4200 maybe 4300 is my guess the amps are underrated..
Ive never really looked too much into the specs of the sundown amps but it seems to me that you should probably upgrade electrical to something that maintains a little higher than 13.5 if your going to run at .7 ohm/ That is going to get really hot really quick.
Bang em if you got em
yeah im on about the sundown saz 3500d amp
maybe some one could give me some advice on what to do plz check thread
http://www.stevemeadedesigns.com/board/topic/104089-which-amp-will-be-better-for-my-mayhem-18/page__gopid__1446891#entry1446891
its about what to do on the amp setup and weather to use a 3500d will be better
all views and help appreiacated
no mention of your electrical. so im assuming stock wtih another battery in the back. youll be in the 11s in no time.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I was getting around 4250 out of mine on a burp wired to .33 :)
And that was at a resting voltage of 12.8...
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
I'm wired to .47 for daily with rise to 1.6 or so
You'll see rated, but you will more than likely have rise so it's hard to tell you what you will really see
At full tilt my voltage stays around 13.4, and the amp has never even gotten warm..my sax100.4d gets warmer and that doesn't even seem like operating warmth even
Edited by BeAlLsTaR13
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
im about to pick up my old saz 3500 back today, running my saz 2k right now at .67 and it gets luke warm, voltage drop down to 12's at times, 220 amp alt, 3 big batteries, big 3. So we will see how the 3500 does at that. But my sax 125.2 gets retarded hot in the summer time, i could cook an egg on it, so i added fans in for this year, and jacob said if it doesnt go into thermal protect. its fine!
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
