Ok, I'm going to be buying an MB Quart DSC480 (Click Here for more info on it) to run two Rockford Fosgate Punch P2D412 (Info Here).
So will this work???
Click Links To View Build Logs
1994 - Mazda B3000 (Daily/Toy/Show)
2002 - Mazda Protege (Daily)
1995 - Hyundai Accent (R.I.P.)
1984 - Bronco II (Restoration Project)
Youtube Channel
dont use a 4 channel for subwoofers. use a 4 channel for mids and high speakers. find a nice 500rms at 1 ohm monoblock for those p2's.
THe amp is bridgeable. You can bridge say channel "1" and "2" and then "3" and "4"
The MB Quart site says the amp will produce 2 x 320W RMS at 4Ω.
Edited by C.Sanchez.A
Youtube Channel
its still better to have a mono amp for subs the way the crossover is setup and the way they are designed are completely different
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
sometimes people run a set of seperates off channels 1 and 2 and a sub off the bridged 3/4. however, i must agree with the others, you should get a mono amp that is designed to push a subwoofer. your suggestion can be done but it isn't recommended, simply because running subs isn't what a 4 channel is designed for.
Should be able to find a alpine m500 for about 130-180
Alpine m500 can't be wired down to 1ohm, which is what he would need to do since he wants two D4ohm subs.
So then he buys a pair of RF P2s that D2.....
And for your price range, why not this amp?
http://www.onlinecarstereo.com/CarAudio/p_21398_Rockford_Fosgate_R500-1.aspx
RF also has the RLine of subs that are pretty cheap.
  • Who's Online   1 Member, 0 Anonymous, 683 Guests (See full list)
