I would of rotated Batts with pos or neg together still
wow you know I actually didn't even think of that. If I didn't make as much progress as I did over the last couple hours I would go do that right now. Actually I might test it out tomorrow to see how it works out
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
Here is why progress has been slow...this is time consuming.
you will see all the speaker wire behind being cleaned up next....
some of them are blurry but I did the best I could to get it to focus
battery terminals are about 1/3 of the way done. Will get them finished tomorrow
used these as a foundation pretty much
Then I laced the negs then ran the pos over top and laced those. Sucks with the neg being black it is a little challenging to see the tie tie
We use that knot to tie our shrimp nets lol. Good work!
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
We use that stuff at work, only we can it tie tie or cats liver. Works wonders!
haha you ninja'd me. I call it tie tie as well.
The cable lacing is supposed to relieve stress on wires right? Is there any other purpose?
a neater way to manage wiring without using zip ties. I used it in aviation. I know it is used in NASA as well and sometimes in information systems like with cat-5 and fiber optic cables and such. zip ties leave a pointy end that is a no no in those situations and the harsh edges can cut into the jacket. I didn't use it for stress or any of that though. I did it for fun and to add a level of craftsmanship to my build that I wanted. Eventually I want all the zip ties I have used to be replaced with lacing. Which is only the runs of 1/0 front to back and my HID harnesses. I first found out about it from this thread on diyma
http://www.diymobileaudio.com/forum/fabrication-tools-tricks-trade/96053-why-dont-more-people-do.html
and then researched it there is a lot of cool info out there about it. Before they had zip ties they did this 24/7
  • Who's Online   0 Members, 0 Anonymous, 1158 Guests (See full list)
