Whats the point of knowing the peak of ur cars cabin
Non the less I must admit I had a good chuckle with the post above. You stating its not a port then turn right around and say you would like to extend the port :rofl:
sorry I was just dumbing it down so you'd understand.
:popcorn:
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
that is long enough for maybe a 70hz line? 40-50'' is what it looks like. and no where near enough port for a tline
that is a ported box
I think you're confused.
if its a ported box, whats it tuned to?
which part are you counting as the box, and which is the port?
oh my, thread went to shit already, "stop watching topic" tool right now ;)
This.
It's not a Tline, but a ported box.
seeing as i designed it, i know its a transmission line. If you think its a ported box please inform us all which part is the box and which is the port?
just a heads up, the dayton woofer tester measures the boxes resonant frequency as 26 - 28Hz, so good luck finding a 27Hz tuning frequency if you think its a ported box. :shrug:
Im not familiar with the dayton woofer tester, but isn't that for test t/s parameters of a speaker not an enclosure resonance? Maybe there is a way to. As I said im not familiar with it. If so I would like more info on this.
You using a program or using real world results for this Fb=27Hz? In car or free air? Not to mention the 27Hz could indicate more like a 37Hz ish tune would it not seeing as "properly designed t-line" is usually flat around 10Hz below tuning? Again I cant put my hands on this enclosure nor have you provided even a tidbit of reasonable info to do anything with other then a pic.
BTW to answer what I think the other two are getting at is in a true T-line. The port area should be = to the drivers Sd. Yours is CLEARLY not indicating a ported enclosure style and function. The ones I have seen getting away from this are tapered and stuffed t-lines starting at Sd of the drivers and tapering from there. Again yours clearly is not. Sure your 3db down is not 27Hz? Thats not a lot of port area to net with that much cone and x-mas. I could see it dragging quite lower then tuning.
So I as well as im sure others would LOVE to hear your philosophy on why you consider this a t-line and what method you used to design it.
My thoughts, looks like a ported box to me too. You need more cow bell?
Evo X build log
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 4586 Guests (See full list)
