1st of all dont use a resistor .2nd you need to have all the ign wires and accessory wires hooked up ,If you t-tapped them ,make sure its a good connection.Also make sure you have a good ground, ground in the kick panel area.Once that is completed then try and remote start it,all the light on the dash should come on,just like when you start it with the key. If the vehical starts and then shuts off after a couple of seconds,then you need to look into the passlock system.Also setting the r/s to voltage will not work as good as running a tach wire.Dont be lazy ,do it right the 1st time.Also i would not t-tap power and ign wires.what you want to do is strip the insulation away from the wire ina spot about 1 inch,then stick a little screw driver inbetween the wire splitting it making look like an eye.Then strip your wire from the r/s back about 1 inch.Take the wire and put it through the eye ,wrap it around .Squeeze the wires together with pliers ,Solder the wire if you want.Then tape it up.You can also use a little wire tie ,to tie the wires together to insure they will not come disconnected.Let me know if you need any more help.
Member of Team 808
Member of Team North East Spl
you said no lights on dash when it tries to RS.. your not getting ign during RS.
go triple check that connection to the PINK wire in the truck
FIXED!!! i went to check the ignition wire and it looked fine, until i unplugged it. the metal contact wasnt in the ttap!! im really embarrassed i cant belive i didnt catch that..... but its fixed thanks for everyones input!!
im happy all my programming was correct, this is my 4th remote start, and last time on my 07 tbss i had to have jack help me. cars are getting to smart these days!
Gary 'Numatik' Eberle
West Sacramento, California
Vehicle build log (1) 'Aayla' Numatik's one and only, bodydropped pasted the doors Chevy S-20 Ext-Ext cab. This project ended after a horrible horrible motorcycle accident. There are so many mods it would fill an entire page in my sig. Check it out if you have A LOT of time to kill. http://www.stevemeadedesigns.com/board/topic/39785-numatiks-doored-s-20-bodydropped-on-doors-ext-ext-cab-10-subs-full-frame-build/?hl=%20numatik#39;s
Vehicle build log (2) 'Snow White' Daily/showstopper 2004 Chevy Silverado
Lays on 22s soon for 26s to run a beefy tire on 4s (4) 5gal tanks, (3)AZOB2 pumps, Slam digital stealth two speed valves with 16 solenoids, Slam SS bags all around, ART upper and lower arms, KP Components 6-link, KP Components watts link, Panther juice 6 22s, Spikes EVERYWHERE. 3,600WRMS total, (5) Kicker amps, (2) L7 15s under raised back seats, 15" screen molded to dash, 36 speakers total all Mb Quartz and Fosgate. Fiberglass console with removable face plates and arm rests, flushed speakers, lots of toggle switches, Playstation 2, rear view camera, Suede and leather seats, suede headliner, Dakota Digital air gauges, voltage gauges, and current draw gauges. (2) XS Power 4800 batteries, Whole truck is flat black and white and the
ENTIRE truck is fully pin striped by TJ Pagano here in Sacramento.
http://www.stevemeadedesigns.com/board/topic/123328-numatiks-bagged-2004-silverado/
"What doesn't kill you makes you stronger. I am proof" - Numatik
Thats why you dont use t-taps!
Member of Team 808
what do you use?
I win!!!
woot..
where's my cookie
I win!!!
woot..
where's my cookie
i dont have a cookie, but have this beer! :drink40:
I solder all my connections
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
for an alarm?? thats alot of soldering!!! lol
it is but it leaves no questions. you get used to it. didnt take me very long to do my truck.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
which is part of the reason some shops charge as much as they do. We charge 200-250.
God damn its hot today. My balls are stuck to my leg.
