why did it blow
i can see why that would affect it, does it help if you have things open before you start playing so the airspace isnt a sudden change for the woofer, i dont really plan on doing this, but you never know, i see videos where people bail out and just thinking it would suck if someone bailed out and blew someones speaker form the change in airspace
so if i'm bumping hard and open the trunk, by changing the airspace quickly i could blow the woofers!? i suppose it makes sense but I never would have thought of that
Not just changing it quickly, you can open the trunk first, then turn it on to full volume and damage woofers. Not all setups would be damaged, but it's a bigger strain on woofers.
Go open the trunk and listen to how they sound out back of the car, you will usually hear distortion much quicker than with it closed.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
your right. very interesting
Yes, It could have "unloaded" the speaker.
what is unloading
Too much excursion, which eventually leads to mechanical damage such as broken spiders and snapped tinsel leads.
what is unloading
ok the guy at the car shop said that opening the hatch caused overexcursion and that the coil was detaching
Yes, opening the hatch can damage woofers.
Depends on your enclosure and car, but the enclosure and car work together, and when you change the airspace on one of those, you totally change how it is tuned and plays.
Most of the time, opening a hatch or trunk releases any possibly back pressure on the woofer cone that would normally help control woofer excursion.
Box tuning gets raised, and if you play a low note at any decently high power setting, it can damage the woofers.
Why do you think it sounds different when you open the hatch?
There´s your answer, at Venezuela there´s something called "open show" , it´s too see who´s the loudest with the trunk open playing music for the people, i saw a lot of damaged subs because of this reason, that´s why they use mostly 4th order folded horns, that stopped the sub unloading on that application...
The whole open windows closed windows deal, your subs fight the compression caused by the fixed amount of air in the car, but when you open the hatch, there is nothing pushing back on the sub, almost in a sense of in a box to free air.
Why can you drive with windows down then and the subs are ok. Or park somewhere and bump hard with a door open and they are ok but you can't have the hatch open.
  • Who's Online   0 Members, 0 Anonymous, 1012 Guests (See full list)
