jsawdy212 Posted May 6, 2011 Report Posted May 6, 2011 might want to check ur rca's completely ive had a set completely melt the casing and stop working on me 2007 caliber 2 Fi ssd 18's rd audio 3250 xs power d3100 (need 2 more) stock alt (soon to be singer 350a) 2.75:1 4th order in progress!
Supercharged DCs Posted May 6, 2011 Author Report Posted May 6, 2011 Will do. Also, My subwoofer is still getting some power, just not much at all. Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
dolarbilz Posted May 6, 2011 Report Posted May 6, 2011 If out of phase will still play n get power just will not be loud
JZeFF Posted May 6, 2011 Report Posted May 6, 2011 I had this problem with my sundown amp.. turns out that the remote gain connection wasnt plugged into the amp all the way.. Something simple, but worth a look.. Just make sure you take it out with the power off. Pioneer x930 bt Rockford t2500 bdcp 18" nightshade v1 DC audio 175.4 RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon) 3x XS power D2700's Knukonceptz 0awg all around
bumonskateboard6 Posted May 6, 2011 Report Posted May 6, 2011 Have the bass knob with you and turn the knob up all the way. Then while having your subs disconnected turn the volume up to where you'd like it to be and play a 50HZ tone, as soon as the knob is a solid red for clipping back the gain on the amp off a hair. The clip light is a little early on these compared to what my o-scope shows me so you should be fine. Also I know it's frowned upon a LOT here but I scoped mine with between 2-4db of bass boost on because it matches up with my mids and highs better. But if you don't have a scope I do not recommend attempting this. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
Supercharged DCs Posted May 6, 2011 Author Report Posted May 6, 2011 Use the first + and first - Alright mate. If out of phase will still play n get power just will not be loud How can I tell if it is out of phase? I had this problem with my sundown amp.. turns out that the remote gain connection wasnt plugged into the amp all the way.. Something simple, but worth a look.. Just make sure you take it out with the power off. Will check the remote wire then. Have the bass knob with you and turn the knob up all the way. Then while having your subs disconnected turn the volume up to where you'd like it to be and play a 50HZ tone, as soon as the knob is a solid red for clipping back the gain on the amp off a hair. The clip light is a little early on these compared to what my o-scope shows me so you should be fine. Also I know it's frowned upon a LOT here but I scoped mine with between 2-4db of bass boost on because it matches up with my mids and highs better. But if you don't have a scope I do not recommend attempting this. Where can I find a 50hz tone? And when doing that, what should I have the gain on the amp, if moved at all? And I don't have a scope so I won't attempt that second bit. Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
jsawdy212 Posted May 6, 2011 Report Posted May 6, 2011 it has a phase dial just like the gain subsonic or lpf 2007 caliber 2 Fi ssd 18's rd audio 3250 xs power d3100 (need 2 more) stock alt (soon to be singer 350a) 2.75:1 4th order in progress!
jmilch Posted May 6, 2011 Report Posted May 6, 2011 Took bass knob off, repositioned speaker wires, still nothing I have had no trouble hooking up an amplifier until this one, though none were of this caliber... Caliber has nothing to do with it. I've installed cheapo amps for customers up to some amps I'd personally never pay for they were so expensive, and they all work pretty much the same man. It sounds like you may have a RCA issue. Have you swapped out rcas? Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
