I am working on a line for those with depth restrictions -- NOT a true shallow woofer but something that just isn't super deep as most of our drivers are big, nasty, deep woofers. The ultra-shallow market is not something we plan to get into but I thought something shallower than the SA line would be nice. Our future "E" series line with stamped frame was not designed as a reduced depth driver either so we would have left this market totally untouched.
SD-2 10" -- 4 7/8" Depth
SD-2 12" -- 5 3/8" Depth
These will fit many under-seat truck enclosure applications.
We had an SD-1 and SD-1 v.2 series some time back that were very popular in the truck market... so naturally these will be called SD-2 as the successor.
The coil will be a 2.5" former with 30mm winding length combined with a 15mm top plate -- this gives us 12.0mm linear one-way travel and 22.5mm before coil leaves the gap. Dual-2 and Dual-4 options will be available with a rating of 500-watts RMS.
We will have 25mm before anything bottoms out -- so a bit over double the linear travel before anything nasty happens.
The cone, spider, and dust cap will be the same as our SA line -- very rugged parts. The latest SA series ventilation spacer will not be present on these models as it would add 0.4" of depth -- the frame will be a 4-spoke with vent holes liked the older SA series drivers. The coil ventilation will also be different from the SA line -- this I will just show when prototypes come in (have to leave some surprises).
Pricing is pending but will be cheaper than the SA line, of course.
I am pretty excited about this line all in all... I should have some samples in a month or so.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Sounds perfect for a build I've been wanting to do for my stepmother & Dad. Keep us updated mate! :)
so if these are rated at 500w, so will they be like everything else sundown makes and handle like 1500?
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
My dad will probably like this for his Ram Quad Cab. Maybe a SAZ-1500D to go with a pair? Yumm....
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Prototypes completed over the weekend way ahead of schedule and I'll have them soon !
If these looks beefy to you for a "shallow 500-watt" driver -- they should... the magnet slug is a full 7" diameter x 1" tall slug -- half of the current SA woofer. So it has some heft !
- Jacob Fuller
The specs before break-in period are as follows as measured by the factory (I will break-in and measure again after arrival) :
SD-2 10" D4 :
Fs: 39.7 Hz
Re: 8.0 ohms
Qms: 5.45
Qes: 0.56
Qts: 0.52
Cms: 0.09 mm/N
Mms: 178 g
BL: 24.7 NA
Vas: 13.8 L
Sens: 83.5 dB 1w/1m
Le: 4.06 mH
SD-2 10" D2 :
Fs: 36.7 Hz
Re: 4.0 ohms
Qms: 5.51
Qes: 0.48
Qts: 0.45
Cms: 0.10 mm/N
Mms: 184 g
BL: 18.7 NA
Vas: 15.6 L
Sens: 83.9 dB 1w/1m
Le: 2.69 mH
SD-2 12" D4 :
Fs: 38.8 Hz
Re: 8.0 ohms
Qms: 6.18
Qes: 0.69
Qts: 0.62
Cms: 0.09 mm/N
Mms: 195 g
BL: 23.5 NA
Vas: 31.7 L
Sens: 86.1 dB 1w/1m
Le: 4.14 mH
SD-2 12" D2 :
Fs: 36.8 Hz
Re: 4.0 ohms
Qms: 6.06
Qes: 0.58
Qts: 0.53
Cms: 0.08 mm/N
Mms: 225 g
BL: 18.9 NA
Vas: 30.2 L
Sens: 86.0 dB 1w/1m
Le: 2.63 mH
- Jacob Fuller
Hmm....
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 1665 Guests (See full list)
