drywall screws are my fav, easy to pre-drill and countersink and they're cheap.
Use more screws. I dont use nails at all.
Hammerdown... 1%
1&1/4" wood screws normally work fine in 3/4 MDF. Predrill prior to screwing. (thats what she said) I have used liquid nails several times. Just make sure to let it cure/dry COMPLETELY before you fire your subs up. (Atleast let it sit overnight, if not for a day or two).
i use 1 1/2 inch drywall screws and titebond III is what i use and ive never had a problem
Vehicle: 2017 Chevrolet Silverado High Country
Electrical: 320A Singer Alt, (2) Limitless Lithium 15ah, Full Throttle FT680-48
Speakers: Stevens Audio SA 6 (ACTIVE), Audio Designs 3”
Subwoofer: (4) B2 Audio XM 8’s
Amplifiers: (2) B2 Audio Rage 2500.1, (1) B2 Audio Rage 1200.6
Processors: NavTv M650 (integration), Helix DSP Pro MK2
Silverado Build Log
Also, when you pre-drill make sure you are using the right drill bit. You want to leave engouh meat in the hole for the srew to have something to grab onto. What i do is us a drill bit that is approx. the size of the center solid part of the screw shaft. so..hold the screw behind the bit and you should see the threads on both sides; bit behind the screw and you may see the very edge of the bit. Hope you understand what Im trying to exaplain, would be much simpler if i had a visual aid.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
The best way is just like theydontwantmusic said. If your joints are tight you can use wood glue and clamps to build a box with no screws/nails. Titebond wood glue will bond stronger than MDF is itself. Then just use a cheap squeeze tube of caulking to seal the inside seams.
But then again, the first few enclosures I built I used fine thread sheetrock screws in predrilled holes, then sealed it up with caulk and no glue. Those boxes held up well (I only put 10w1s in them not like I was stressing it at all) and I know 2 of them are still being used 14 years later. Once you build a few you'll find the glue only technique works well.
2007 Pacifica
  • Who's Online   0 Members, 0 Anonymous, 1619 Guests (See full list)
