I have seen it happen locally to a guy in Memphis. His BTL blew sky high and caught on fire with a kicker zx1500 on it!!!!!!!!! I have never been a fan of Fi. I think it is a lot of hype and they have NOTHING special about what they build until the new neo setups came out.
Funny part about this setup you have is it appears to have never been given much power either. I am gonna say piss poor connections on the tinsels and voice coils or obviously tinsels that become broke in the middle. The worse and worse the connection, the more heat it generated... compounding the problem of thinner and weaker tinsels which have become increasing brittle and less effective as a conductor. Eventually it breaks and then arcs big when makeing contact, momentarily of course, as the sub is still being driven by the other coil.
I have heard of tinsel problems on ascendants as well... If you play them daily and ride with your tunes jamming all the time, they are destined to fail even within reccommended enclosures and under-rms power levels
Not a thing wrong with the tinsel leads...it's the old addage of buying a car and driving it into a bridge..which is obviously the cars fault right?
The issue is this (if you want to take the time to read it):
There is nothing wrong with doing the leads like this and it only has issues and develops problems in the following situations.
There are 3 things that come into play.
1) Those coils that are ".5ohm" are not ".5ohm" in parallel, they are .35ohm dcr. The power supply cannot supply enough current on the rails to the output side stage of the amplifier so it starves itself into trying to make power that it simply cannot make. Kicks out DC voltage and things get very nasty very quickly...which continue to read and I'll explain more.
2) Korean/Chinese amps. For those who do not know the bigger the amplifiers get the more issues you are going to run into. These things are designed and built on a power supply that has a bank that is plugged into a wall on a resistor that is always constant, not a sub-woofer. In order to get efficiency up so you can get more power out of the amp and put in less and less to get efficiency up above 85% or so they ramp up the switching frequency on the power supply of the amplifier itself. This ranges from board to manufacturer..but all of the bigger amps all have the same exact issue. What happens at these frequencies is you are reaching the range of "Microwaves". The amplifier does not filter this stuff out...and you cannot hear it as it is much higher then the frequency range that human ear can detect. Signal goes from the amplifier to the terminal block...the frequency range is outside of what the terminal block is so it continues to the tinsel leads. The tinsel leads have the current and voltage going through them in the first place which already makes heat present and why the spiders are treated with flame retardant coating to prevent it from catching on fire. What happens is the amplifier's switching power supply actually 'Microwaves' the tinsel leads at the frequency in which it is switching at which happens to be very close to the resonant frequency of the size of wire and material of the tinsel leads themselves.
When you throw a piece of aluminum foil in a microwave in your house...or a CD..what happens? There is a HUGE generation of heat because on a molecular level the material itself is vibrating back and forth at that given set of frequencies...which is how a microwave warms your TV dinner up.
3) When you start to drop an amp below 1ohm more heat is being built up because the power supply side of things of the amplifier simply cannot handle the demand that the output stage is wanting to get. When you do not have a subsonic filter...or one that is set improperly...you then start to make this thing that you've just microwaved move...
Take a can of coke, pop it open and bend it back and forth a few millimeters...within it's mechanical limitations that tab will never break. Now if you start to bend it past its mechanical limitations is when you start to get into trouble. This is where the subsonic filter comes in and making sure that you are not playing full power below port tuning frequency of a sub. If you already have something that's hot from running it hard on one of the Korean amps and you start yanking the soft parts past their mechanical limitations more and more heat builds up...
You get to the point where so much heat builds up that the spiders start smoldering...they won't catch on fire until you've clipped the signal to death, vaporized all of the flame retardant spray that the spiders are soaked in and then it smokes. (square wave form, dc voltage and induction heating out of the amp because the power supply cannot handle what you are doing to it)
It's not the sub, there is absolutely nothing wrong with running those leads like they are. What's going on is an issue of the big cheap Korean amplifiers in and of themselves...and total ill-regard to what a microwave and conductive material does.
Hope this helps you understand...if you run a Crown A6000Gti you'll never have a problem...because it's an A/B amp....the other stuff that is cheap...don't run it below 1ohm or you are going to have nothing but problems because in order to get that big power cheaply and cut out on the parts that are going into the amplifier the switching frequency of the power supply must be ramped way up...in turn microwaving woofer parts.
There will be no finger pointing as I've already tested all of this stuff and know exactly what is going on. Don't design an amp on a resistor...and don't wire an amp below 1ohm, don't clip the piss out of it to get the tinsel leads so freaking hot that they glow, no bass boost etc. you'll never have a problem.
Moral of the story? Lay off the what I like to call the "stupid button". It will hurt your wallet every time...because stupidity is not covered under any warranty at all.
Regards
Agreeing with previous person that quoted you on page 2 as well, you are wrong. There is no magnetron present in an amplifier nor at the tinsel leads which is required to produce enough microwaves to create the aluminum foil/cd sparking effect you are talking about. The switching frequency of the amplifier will not create microwaves in significant amounts otherwise you would probably be dead by now.
What did likely happen is that excursion caused flexing of the tripple joint which cracked wires in the tinsel lead causing fewer connections (and therefor higher resistance) at that point.
You do not need a magnetron to create microwaves...
what is being said is that because the Korean Amps increase the switching frequency on it creates microwaves because the amplifier is switching at such a high speed it is same frequency of a microwave causing it to travel to the tinsel and fry them. If the Korean amps did not switch at such a high frequency to make more power than they should, this problem would not be present.
Fi BTL 15 N2 D2
-4.5 net..30Hz/Birch and Braced
-AQ 2200D running at 4-ohms for meantime...
-Big 3 KNU 1/0
-XS 1200
-Sundown 100.4 SAX
-Front Stage: CDT CL-61
-Rear: Alpine Type-SA
-HeadUnit-Pioneer AVHDVD-3200
-2004 Saturn Ion
Best score to Date is a 143.1 at the kick with 2 RF HX2 10's in a PWK box!
BUILD LOG---15 BTL...Shit is loud Son!!
You TUBE---RIGHT HERE
Is it just me or are the people trying to bash fi forgeting that this guy was running his sub at .35
On a bdcp at that
I was at 1.4 OHMS, FUCK! Rcock solid volatge. There is NO signs of abuse OR any Thermal damage. I had a local shop check out the coil and there guess was tinsel lead FAILURE, Im not saying that i am not paretially at fault or possibly may have done something wrong BUT I never seen any kind of sign of I was doing any thing wrong. LIKE I SAID IM NOT BASHING FI! I sell a lot of subs at my shop and NONR of them would have lasted half this long on this kind of power. All I know now is tomorrow im goin gto contact Fi and see what its going to cost me, Than I'll contact PSI. After that I will decide on maybe a whole nother set up with 6 12's or something sic. I have 3300 watts RMS the wiring, alt and great RCA voltage so I think im pretty set here....
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
Regards
Spot on! I love forum members who know something and do not continuously regurgitate the same forum bullshit over and over... effectively clouding the minds of young readers and those wanting to learn.
I think what you say is Bullshit..This happened because of user error most likely.The man was running 3,3oo watts to a 2,000 watt sub, which is bound to cause problems over time.
Have you ever ran a Fi subwoofer yourself?
You, sir, own a Fi sub. I would expect that out of you. Get Nick or Scott on the phone. A "fully loaded" BTL is a 3000 watt rms sub and that rockford has never ever ever ever ever delivered 3000 watts rms of non clipped signal in its life due to impedance rise and voltage supply. I will bet my house on it. Asking if I have ever ran a Fi sub... lol My Fi subs were ok. Nothing special. My Ascendant subs were the same thing. The Havoc had me hooked for a while.
Lastly, cause problems? The hunk of shit caught on fire. IS that a normal problem within the bounds of giving a sub its approximate rms power?
You just caught me on a very bad day, so if this sounds brass I will apologize in advance (this is to everybody that reads this post as well). I've been up with the flu for the past 12 hours, every joint on my body hurts...and quite frankly, you chapped my ass.
Now,
Does induction heating mean nothing to you? Can you not comprehend or understand the fact that the 16 tinsel leads that are inside of the sub actually start to move and glow due to the output stage not being shunted or filtered? Did you also miss the point that the spiders are SOAKED IN FLAME RETARDANT MATERIAL...and it has to vaporize in order to catch on fire. The lack of an adequate subsonic filter only adds nitro to the oil fire..if you have something that is already so hot that it is glowing..and you start to bend it back and forth past its mechanical limitations you only added stupid to more stupid at this point.
Truth of the matter is, the issue is the basket itself. I hate building with flat tinsel leads, it adds SO much time and is SUCH a pain in the ass. However, it is the best way to do it with the geometry of every basket except the 18" 12 spoke with a curva-linear cone...you don't see anybody having 'tinsel slap' issues out of the IB3 18" woofers in the home theater environment..because those would be the first guys to bitch. It really is the best bandaid for a cut that really needs stitches.
Sewing the tinsel leads on top of the spider is far more problematic simply because the cone beats the piss out of the tinsel lead when it convexes in, then the thread that is tied in on rips out of the poly cotton spider and then you have 1.5" more lead then what you need...then it shorts out.
The SMD does not have any tinsel lead issues because they are stitched on in-between the spiders and WAY under the cone so the cone can not hit it.
Bottom line is..free floating leads in a properly designed basket with the correct geometry is the way to go. The round lead does not have induction heating issues and it does not start to glow. There's not a snowballs chance in hell that we will stitch round lead on top of the spider for the cone to beat it up and fail.
With that said, our new high excursion baskets fix all of the stupid that is currently associated with the 12 spoke..and the eclipse basket and every other basket that is on the market. None are done exactly correct, each one has its own set of issues...and it will use free floating round leads and not have slapping issues.
If this pissed you off, sorry. But i'm far from in a mood to let a sess pool stupidity breed right now.
Authorized Ascendant Audio Dealer! Message me for information.
If you can't explain it simply, you don't understand it well enough -Albert Einstein
"I have a plausible excuse for not liking you. And you know why."
ps. induction heating does not create radation or anything at all...you are around it every single day, radio waves..micro waves etc.
You are looking at a switching frequency from 80-120kHz.
http://en.wikipedia.org/wiki/Induction_heating
People cook with it every day, and they melt steel bars as well.
http://en.wikipedia.org/wiki/File:Induction_heating_of_bar.jpg
Just so you know, the tinsel is not the part receiving the induction heating, and again, microwaves are not being created in sufficient amount to cause the heating you are describing, otherwise you would be dead by now.
That said I agree on the baskets and lead slap issues.
Hammerdown... 1%
I'm running (2) Sundown 3000's on my single BTL 18 and I don't have issues. It's all about setting it up correctly and being responsible with the volume knob.
1992 GMC Sonoma
2008 MECA S1 Champ, 2010 MECA S2 Champ
I like this VOPA guy.
I disagree with nick. You're blaming your parts failing on amplifiers that get used VERY REGULARLY, and have caused no problems for me and MANY other people.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
You're also talking about drivers that have also not failed just as many times as the amplifier mentioned when used correctly. With your logic it still equals the same.
nor have I ever heard of a BTL, or Mayhem bottoming out.. Its impossible unless your spiders are torn all the way around the coil.
I can show you a Video I made one a BTL 18 bottoming out on 3krms 6.5 cubes, 28hz.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
I have put over 60+ amps thru my single 15" BTL, I have never had any tinsel issues.
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
