focused313 Posted June 1, 2011 Report Posted June 1, 2011 Headunit: Pioneer AVH-p4000DVD One of my amps was acting stupid, so I started unplugging RCA's to see which channel was working while the HU was still on. Shortly after, I turned the car off, turned it back on the the HU was dead. First I checked the fuse on the back of the stereo...good. Checked the radio fuse in the fuse box of the car...good. Took a DMM and checked for voltage at the wire harness that plugs into the HU...12.4v. Now...I don't know anything else that could be wrong, other than a blow head unit. Given that this is completely my fault, as I know I've read somewhere that you should not disconnect and connect wires while the HU has power, do I have any options? Am I missing something to trouble shoot the issue? Learning Everyday. Pioneer AVH-P4000DVD Alpine SPS-610C BXI-2008D (2) SWR-1242D / Ported
Mtnbikecrazy55 Posted June 1, 2011 Report Posted June 1, 2011 Did the harness come loose when you pulled the rcs's? I hate long signatures.... ...what the fuck is wrong wiht you you fucking fuckity fuck fuck head... Mtnbikecrazy55 Feedback
bass_stalker Posted June 1, 2011 Report Posted June 1, 2011 ^^^^^^^^^^ this x2 JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
RickyFriery97 Posted June 1, 2011 Report Posted June 1, 2011 check and make sure the harness is all the way in like stated above ^^ Get a DMM and check the power wire, ignition wire, and the ground one of those may be bad and it could also be bad behind the factory harness ive had this happen on my burban and a friend of mines car and had to re run new wires 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
focused313 Posted June 1, 2011 Author Report Posted June 1, 2011 Did the harness come loose when you pulled the rcs's? I never pulled the RCA's. All I did was disconnect them in the back next to the amp, but no, the harness didn't come loose. I haven't checked the ignition wire though. Should I assume that merely moving RCA's around on the amp shouldn't cause the radio to no longer power on? Learning Everyday. Pioneer AVH-P4000DVD Alpine SPS-610C BXI-2008D (2) SWR-1242D / Ported
Bakerman Posted June 1, 2011 Report Posted June 1, 2011 Wow...so u never unhooked anything from thee radio...just the rca's at the amp? I'm stumped...pull your radio nd check the voltage and grounds @ the radio...if one isn't working, follow it till you find out where it shorted at.
focused313 Posted June 1, 2011 Author Report Posted June 1, 2011 Wow...so u never unhooked anything from thee radio...just the rca's at the amp? I'm stumped...pull your radio nd check the voltage and grounds @ the radio...if one isn't working, follow it till you find out where it shorted at. I want to thank everyone that replied. I still don't have it working correctly yet, BUT, I ran the accessory wire from the harness to my switch to turn the amp on, and the head unit powered up. Now I know it's a wiring issue somewhere, I just have to find it. I'm just happy it's coming on. Thanks again to everyone. Learning Everyday. Pioneer AVH-P4000DVD Alpine SPS-610C BXI-2008D (2) SWR-1242D / Ported
RooTxBeeR Posted June 1, 2011 Report Posted June 1, 2011 Ya, I was going to say, unplugging RCA should never short anything like what you are explaining. Glad you figured something out because if you didn't I don't think anyone could have helped you figure out was wrong. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
focused313 Posted June 1, 2011 Author Report Posted June 1, 2011 Ya, I was going to say, unplugging RCA should never short anything like what you are explaining. Glad you figured something out because if you didn't I don't think anyone could have helped you figure out was wrong. Now that I have that right, I guess I can start another thread about my dang on amp. Learning Everyday. Pioneer AVH-P4000DVD Alpine SPS-610C BXI-2008D (2) SWR-1242D / Ported
