I was going to wire my 2 subs up like this...
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=12#results
and found out that my amp has 2 sets of terminals for subwoofers, and the digram only shows 1 set being used. should i just use 1 set or do the two sets (dont know how to wire them tho)
amp - aq2200d
subs - hdc3 d1
Car: 2002 Buick Regal
Wiring: Knu Kolossus 1/0 + JL 4 Gauge
Big 3: Stinger HPM 1/0
Alternator: Stock 135 Amp
Batterys: Optima RedTop (Hood) XS D3100 (Trunk)
HeadUnit: Pioneer DEH-4200UB
Subs: (2) AQ HDC3 12's
Sub Amp: AQ 2200D
Sub Box: 4.6 Cubes @ 36hz
Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's
Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25"
Speaker Amp: AQ4x90
Sound Dampener : 75 Ft Fatmat
They have 2 sets to make hooking up 2 subs easier, both are paralleled inside the amp so hooking up D4's will get you the 1ohm/4ohm load you need.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
is your amp mono block or 2 channel if its a mono block then just one set. on 2 channel you prob want to bridge it
what subs and amp are you running? depending on what impedance the subs are and what your amp can run at you may be able to hook each coil into its own channel but its all dependent on what subs and amp youre talking about
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
assuming your amp is a AQ2200d like your sig says
use only one set
there two sets for ease of wiring
i also own the amp
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
  • Who's Online   0 Members, 0 Anonymous, 723 Guests (See full list)
