Just throwing this out there. Op, you mention you don't buy cheap shit. You like the expensive stuff, right? Must have money to throw around. I on the other hand, don't. So instead, I buy equipment that is better quality than JL, and cheaper at the same time. I buy things because of their quality, not their price tag.
as long as you didnt pirate your music and your HU isn't turned up excessively and your gains are set correctly, i don't think it's a clipping problem.
Heres my two cents. i always get worried that i'm clipping the shit outta my sub, sometimes just because it's loud. sometimes i smell what i think is coil, but is actually the smell of the box, spray paint (i'm cheap :pardon: ), caulking, wood glue, etc... my point being is that if the smell is subtle, then it could just be the smell of the box when the subwoofer is playing. smell the port (if ported) or the box when the sub is playing and when it's not playing. see if it smells similar.
also, smell it after a few hours of not bumping.
hope that helps! :drinks:
LOLWUT? Songs that clip are clipped from the source not the way you obtain the music. My pirated music shits on Itunes bought music
I like my JL setup, gets loud enough for me and sounds good. I don't have the skills, tools or a place to build a box. The shop I go to had the JL's preloaded in a JL High Output box, hence the reason I bought mine :D
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
to the op: just so you know clipping and distortion are not the same thing. Usually a clipped signal is inaudible. Do your homework and fix your own problem. Do NOT trust a shop to do it for you. Its your money into your system not theirs. MOST shops (not all) either don't care or know how to CORRECTLY set amp gains. Case in point next time your in your local shop, ask them if they have an oscilloscope. When they go "what's an oscilloscope?" RUN! The ONLY way to CORRECTLY set your gains its to use one. (with the exception of the DD-1). If they tell you they set the gains with a DMM (Digital Multi Meter) they're just guessing by the voltage NOT the signal. You could still be clipping. Hence the heating up of your coils. Or it could even be before your signal even gets to the amp. Once it reaches you amp, your amp does what its designed to do and AMPLIFIES the clipped signal. Like I said do your homework.
FYI 1 10" CAN and WILL hit harder then a 15 or 18. Its all in the setup
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
Thanks for all the responses everyone, did some homework, got it to a shop and yes, first question I asked was "do you have an oscilloscope?". They had it and yes... I was doing it ALL WRONG!!! They helped me and my truck sounds waaaaayyyy better, my sound seriously improved by a ton and the sub sounds super clean.
Honestly I haven't heard live any DC or Fi sub, but to me, this JL 10" W7 is the best sub that I have heard, it's a million times better than your 12" subs from the other "mainstream" retailers.
that's why you paid for that jl...i'd take any dc or fi sub over that jl..other than maybe the level 2 8..
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
yeah i've got a friend who pirates stuff from some other backdoor source, and it doesn't distort. but me i'm a lazy bum and got a lot of my music off of limewire. most of it wasn't worth the space it took up on my computer because it sounds like someone took a shit on it.
i'm not in the mood debate right now, so i will say you have made your point and i have made mine.
i was simply stating that he might just be smelling the box.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
Even then, you could put it in a quadrouple bypass 22nd order fully inverted bandpass t-line box & make it sound louder...or something like that. :pardon:
(Yes, I'm being sarcastic. But seriously, I bet if you built a good enough box it probably could. For a second... :peepwall: )
POTATO!
What's the "bass volume" on your hu set up?
If your gain is set low "at 10 o'clock" (slight turn) or way to high at almost a full turn "10 o'clock"
If your bass boost on you hu is turned way up that'll funk your world up no matter what power your amp is rated for
My gain is very low at the moment, only like half inch above 0 on my amp.
My HU is a Clarion DVD unit VRX755. It has BASS BOOST (ON or OFF) and you can adjust the Bass, it has Gain (goes from 0 db to 16db), it has Freq (goes from 50hz to 120hz) and it has a Q function (goes from 1 to 2). Same thing for mids and highs.
  • Who's Online   0 Members, 0 Anonymous, 977 Guests (See full list)
