JL Audio / Studio Six Digital Iphone App vs. Termlab meter
Has any of you guys tested out the JL Audio / Studio Six Digital app to test your sound system with your smart phones?
JL Audio app Itunes Link
It has an SPL meter, real time analyzer, speaker polarity test and calculators to somewhat help with audio testing. Also, you can adjust mic sensitivity. It's a free app. I'm curious to see how it could compare to a traditional spl meter, if used and in the same spot, as well as to find out what the Mic Calibration on the JL Audio app should be for it to be somewhat close to what one makes on the meter.
Bass Music Producer • Photographer • Graphic Designer
Deep Sector Boom...
No phone meters are anywhere near what te termlab is. The mics aren't built to measure levels of sound pressure. Simple enough, don't put any merit at all into phone meters...save up for a term lab.
Nope...mic isn't going to read above 110-120 and will not even capture the bass because the frequency is below its response range.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
That looks like fail, no phone has a good mic for that, i also saw an application for ipads, sucks ass too lol
Did you even test it on your system? Like I said before, you have to calibrate the app's mic sensitivity. If you know what you average on the dash, then you go into the app's Application Setup and change the Mic Calibration to over 70.0 or however much, so that it reads about the same number as the termlab from the same dash location.
I set the mic calibration to 70.0 and snapped my finger in front of the speaker on the iphone and registered a 148. The mic calibration adds db's to the reading. Normally if it was at 0 my room noise would be 33 db or so, if calibrate to 100, it would show 133 db. The frequency response is between 20hz-20khz.
When calibrated this does not replace the termlab, because it's what's used in competition. Since it is free, it gives competitors with access to an iphone, a general idea of where his or her system could be hitting at, if they don't have access or time to get to a termlab to test it.
If you want to learn about the company and other equipment they've developed: http://www.studiosixdigital.com
Deep Sector Boom...
The termlab is a pressure sensor. The iphone is a microphone for transmitting voice over phone calls. its not evenclose to the same thing. maybe its close to the termpro meter prior to the termlab.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
There is so much fail in this post I want to bash my head again a wall.
*sigh*
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
No it will not. It will only waste the competitor time due to the fact that this app does not monitor PRESSURE as the termlab does. Please do not listen to this information as it is completely wrong and incorrect. If you want to know where your at db wise, do yourself a favor and get to the show earlier and try to get some meter time from the judge. Most judges will let you get a practice run if you get there earlier enough. I'm so sick and tired of mis-information going on around here it's driving me up the damn wall. If you don't understand what reading pressure is then I suggest you take some time and do a little research. Thanks for playing.
:madsign:
:ninja:
  • Who's Online   0 Members, 0 Anonymous, 924 Guests (See full list)
