evermaxx Posted July 4, 2011 Report Share Posted July 4, 2011 So my RCA broke off and the stem got stuck inside the amp. I tried a dwell screw like many have told me Nd it failed. So I was just gonna use the other channels (3/4) but when I hooked it up it went right into protect. So what do I do ?! Quote Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench Link to comment Share on other sites More sharing options...
**Hollywood** Posted July 4, 2011 Report Share Posted July 4, 2011 Take it apart use needle poke it out , form the inside of amp ! Quote Link to comment Share on other sites More sharing options...
kam311 Posted July 4, 2011 Report Share Posted July 4, 2011 Shit man, I wish I could help you on that one =\ Quote so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs Link to comment Share on other sites More sharing options...
evermaxx Posted July 4, 2011 Author Report Share Posted July 4, 2011 I tried, there's no access to the RCA in this amp Quote Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench Link to comment Share on other sites More sharing options...
Supercharged DCs Posted July 4, 2011 Report Share Posted July 4, 2011 Have you tried using a magnet to draw the stem out? Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012. Link to comment Share on other sites More sharing options...
evermaxx Posted July 4, 2011 Author Report Share Posted July 4, 2011 Yeah, no luck. Quote Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench Link to comment Share on other sites More sharing options...
**Hollywood** Posted July 4, 2011 Report Share Posted July 4, 2011 Put jb weld in end of finishing nail put inside of stem and let set over night then pull out , hey worth a try Quote Link to comment Share on other sites More sharing options...
homiewes Posted July 4, 2011 Report Share Posted July 4, 2011 only thing to do is is grab the amp with one hand and smash it into little pieces onto the ground.. Quote My youtube channel, please subscribehttp://www.youtube.com/ballinblaza Link to comment Share on other sites More sharing options...
SnowDrifter Posted July 4, 2011 Report Share Posted July 4, 2011 Try pressing some chewing gum around it, then see if that can pull it out. If not, take a q-tip, cut off one of the ends so you only have the shaft part, put a TINY amount of super glue on it, press it to the rca stem, blow on it + count to 30 for it to dry, then pull it out. Good luck with it. Just as a side question: How did you manage to break the end off an RCA cable? Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
evermaxx Posted July 4, 2011 Author Report Share Posted July 4, 2011 I have no idea, it just fell out so I tried to plug it in & saw it. Quote Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench Link to comment Share on other sites More sharing options...
