Still need bracing.
I will add that after the whole port problem...
Depending upon how you brace it, you may still have a port problem...
How's that?
If you end up using something that takes up a respectable amount of room (like 2x4s) you lose airspace, and raise your tuning. Which will require more port length to bring it back down.
If you're bracing using dowels, the effect won't be as drastic, but again, depending upon how you brace it, there may be other issues. Like there not being enough space to run your dowels (which is actually what I'm concerned with).
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
The height of your box is 18 inches...and you have three 6 inch aeros. That dog won't hunt.
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
2 12's is more motor force and only a little less cone area...i'd do that. or just don't do a wedge box...they complicate everything.
Hmm, let's rework this then. I agree, shouldn't be building a wedge box for my first box.
Edited by Shigshwa
i cant imagine a wedge enclosure for a FI btl. Im pretty sure the motor will be hitting the bottom of the box...
1999 Monte Carlo
Sony CDX-GT34w
2 Alpine Type R 12"s in 4 cubes tuned to 35hz
American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms)
Stock alt, Stock batt, Big 3 Upgrade
Boston s55- 5 1/4s (doors)
Boston s95- 6x9s (rear deck)
do sub up port back.
1999 Monte Carlo
Sony CDX-GT34w
Yeah, that would work.
I'm trying to balance performance and aesthetics together, but my car isn't working with me, so I guess sub up is the only option for a square box.
Doing a 18 in a wedge and doing it right in a trunck is alot of work. Trust me. Go with a 15
I know what you mean, but the sheer size of an 18 is total shock and awe, you know?
Also
(Might have to shave it to 17, give the driver some room to flex.)
Edited by Shigshwa
1.2" Dowels for bracing. You need to realize that bracing will take up space in the box therefore raising your tuning. I'd run a double baffle setup, with some 1.2" dowels from top to bottom and front to back. Also, any reason you are set on an aero port? 2 7" aeros wouldn't personally be my setup of choice.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
  • Who's Online   0 Members, 0 Anonymous, 624 Guests (See full list)
