Port Triangle? Yes or No
22 members have voted
  1. 1. Should I use a triangle where the port splits?
I was contemplating this also. If separating the two waves with the flat top T is most beneficial, then why not just run the divider all the way down. In other words what are the benefits of having a shared port? Don't mean to thread jack, just seems like a question for those reading this might also be interested in.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
less surface area for the moving air to interact with
there is also technically only 1 exact size the 45 should be, the midpoint of one 45 that makes up the triangle should be the ports width away from the port edge. whether its rounded, 45'd or straight port edge the distance should never be more or less than the ports width
Edited by Decaf
i wouldnt have done a center port if i was trying to get the most out of it anyhow.
You and Nate. Man. Every time y'all post I'm asking for more info.
So...can I get more info?
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
probably that a wider port would make it more efficient is what i'm thinking. imagine 8 little ports vs 1 big one, just not to that extreme
  • Who's Online   0 Members, 0 Anonymous, 941 Guests (See full list)
