onebadmonte Posted July 26, 2011 Report Posted July 26, 2011 You got a pic of that dual alt setup. A slipping serpentine belt means you don't have enough pulley wrap around the accessory you are trying to drive. You might have to step up to larger idlers to fix the problem. Good luck. Quote Warhorse vs A Pair of SMDeez build Olds Cutlass Cierra IB build 2 Fi IB3 18s
onebadmonte Posted July 26, 2011 Report Posted July 26, 2011 Also the Dayco website is very good for searching by dimensional size ie. pulley diameter or belt length. It will give you part numbers and you can search for them at the summit racing site. Dayco Dimensional Lookup Quote Warhorse vs A Pair of SMDeez build Olds Cutlass Cierra IB build 2 Fi IB3 18s
n8ball2013 Posted July 26, 2011 Author Report Posted July 26, 2011 of course the fan blade blocks the pulley thatst here. I dont think belt wrap is the issue. Im leaning on the tensioner is starting to go so thats on its way. i just wanted to go to the best belt out there while i was at it. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
newls1 Posted July 26, 2011 Report Posted July 26, 2011 the green one ive only seen steve run. it has 7 or 8 ribs so you would have to cut ribs off. i have not been able to find the belt though. the more common belt is the goodyear gatorback. ive talked to several people who say that belt got rid of the slipping. i have the same squeal only at high rpm and im about to get a gatorback. Not so sure on that. First, I doubt HIGHLY Steve would put a belt on a tahoe thats worth MEGA money that he had to cut to make work, just doesnt make sense. Also, Gates will have a 6 rib belt in proper length to accomodate these apps. Remember, these green belts are for heavy semi's, so these long lengths that we require for multi alts is NO PROBLEM as some of these SEMI trucks take god aweful long belts.... Quote I love my staffie So anti FACEBOOK it isn't even funny
onebadmonte Posted July 26, 2011 Report Posted July 26, 2011 Yeah, looks like you've got plenty of wrap on those pulleys. The tensioner will be a good start. Good luck. Quote Warhorse vs A Pair of SMDeez build Olds Cutlass Cierra IB build 2 Fi IB3 18s
newls1 Posted July 26, 2011 Report Posted July 26, 2011 You got a pic of that dual alt setup. A slipping serpentine belt means you don't have enough pulley wrap around the accessory you are trying to drive. You might have to step up to larger idlers to fix the problem. Good luck. Negitive ghost rider..... He just needs to play with either 1 of 2 things OR BOTH!! Either get a 1/2" shorter belt, install it and see how it is then. Or replace tentioner and shorter belt and try it then.... No need to touch any idler pully Quote I love my staffie So anti FACEBOOK it isn't even funny
Ninja_v1.0 Posted July 26, 2011 Report Posted July 26, 2011 jiggle the power cord *slowly walks away* Quote When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
onebadmonte Posted July 26, 2011 Report Posted July 26, 2011 You got a pic of that dual alt setup. A slipping serpentine belt means you don't have enough pulley wrap around the accessory you are trying to drive. You might have to step up to larger idlers to fix the problem. Good luck. Negitive ghost rider..... He just needs to play with either 1 of 2 things OR BOTH!! Either get a 1/2" shorter belt, install it and see how it is then. Or replace tentioner and shorter belt and try it then.... No need to touch any idler pully You're right. Now seeing his setup, it's obvious the belt wrap around the pulley isn't the issue. I would do a new tensioner first, assuming this kit was just installed, and the belt is new and was included in the kit. I'd want to see where the tensioner lands with regards to stock before making the jump to a shorter belt. Too much tension will wreak havoc on accessory bearing. If you wanted to be able to drive like a mad man and keep a multi alt setup from ever slipping you'd have to make the jump to 8 or 10 rib belt. Quote Warhorse vs A Pair of SMDeez build Olds Cutlass Cierra IB build 2 Fi IB3 18s
David Posted July 26, 2011 Report Posted July 26, 2011 actually steve does cut his belt, i have seen him do it. Quote
newls1 Posted July 26, 2011 Report Posted July 26, 2011 actually steve does cut his belt, i have seen him do it. I stand corrected Quote I love my staffie So anti FACEBOOK it isn't even funny
