Fish Chris Posted August 2, 2011 Report Posted August 2, 2011 Okay, first off, I'm about a 60% SQ, 40% SPL kind of guy. Loud is great, as long as it's below 30hz. Anyway, the thing I'm kind of locked into, is my power situation. {my old RF Power 1000, 5 ch. makes it really tough to switch. Great amp, but puts all your eggs in one basket } So, I've got about 760wts (into 2 ohms) to play with. I could make 960wts into 1 ohm, but I really like the efficiency, and cleanness of my amp run into 2ohms vs. 1ohm. As for space, I can easily build / fit an enclosure of 7 cubes, after port and speaker displacement. I might be able to squeeze 8 cubes, if that 1 extra cube would make a big difference. I've been running two 12" eD 13Kv2's for about 3 years. They have done great. But I finally cracked one of the spiders, and so now it pops a little on fast hits.... + after 3 years, I'm just kind of board with them anyway. So, I decided to go with two 15"s this time around. I think I probably got ahead of myself, and like a dumbass, I ordered a Dayton HO 15" yesterday morning (first of two)(they do offer a 45 day money back guarantee though). Of course I researched them, and everybody says they are fine SQ subs. Of course the price was not bad either...... But geeeez, not much of an X-max ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ So now I'm wondering if I should have spent a little more.... well, ($200 more for the pair) of Fi Q 15"s ??? Sorry for my long post, but if you read nothing else, the $10K question is > Given the same 760 wt RMS, would I really see (hear) much difference, if any, between a pair of Dayton HO 15"s, and a pair of Fi Q 15"s ? Thanks in advance, Fish PS, An even crazier (but possible) option, is that I could go with my same 760wts RMS, and all of the 7 to 8 cubes of space I have available, ran to just one 18" Fi Q ! Heck, that would cost about the same exact price as two Dayton HO 15"s, (a lot less than two 15" Fi Q's) and because of the huge difference in X-max, would (in theory) move twice as much air ! My only concern there is, I do "also" listen to a lot of old school stuff, with normal, slightly higher frequency, guitar and drum bass. Just not sure "how fast" an 18" can really be ?
Fish Chris Posted August 2, 2011 Author Report Posted August 2, 2011 Oh hey, here's the totally dumbed-down version of my post above, for anybody that just doesn't care to know any of the other details, or is too lazy to read them... > Given the same 760 wt RMS, would I really see (hear) much difference, if any, between a pair of Dayton HO 15"s, and a pair of Fi Q 15"s ? Much thanks, Fish
bassrace Posted August 2, 2011 Report Posted August 2, 2011 The pair of qs prob need more powa but the single 18" should do the trick 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
Fish Chris Posted August 3, 2011 Author Report Posted August 3, 2011 Thank you Bassrace. One Fi Q 18" huh ? Well check this out, I'm pretty good at math. I just sat down and calculated out the volume in liters, of air moved with the maximum stroke of my: eD 13Kv2's (for two) = 2.19 liters and a pair of the Dayton HO 15"s = 2.7 liters (only a 19% gain from my eD's ) and for a single Fi Q 18" = 4.5 liters !!! For a greater than 100% gain ! ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ So still, my only concern is whether the Fi Q 18" will be fast enough, and tight enough, to play nearly all of my music well..... and not "just" my techno bass stuff (no worries about this stuff.... I'm confident it will pound rediculously hard, and deep). Hmmmmmm...... I have until Friday to decide whether I send the Dayton right back with Fed Ex, instead of accepting it..... Peace, Fish The pair of qs prob need more powa but the single 18" should do the trick
6berry Posted August 3, 2011 Report Posted August 3, 2011 what it will play is based heavily on the box that its in. use the right box and it can play whatever music you want 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
kam311 Posted August 3, 2011 Report Posted August 3, 2011 what it will play is based heavily on the box that its in. use the right box and it can play whatever music you want X2!!! It's all in the box man so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
Fish Chris Posted August 3, 2011 Author Report Posted August 3, 2011 Don't worry. The box will be spot-freaking-on. I'm totally anal about tweaking every dimension, calculating port areas, lengths, frequency of tuning, etc, etc. I just spent 2 hours tweaking over the RE box designer.... (BTW, I don't do drugs, in case you were wondering ... hard-core OCD sufferer though. Anyway, this is what I came up with: Box width 32" Box height 30.5" Box top depth 19.5" Box bottom depth 27" Wood thickness .75" Sq port height 29" Sq port width 4.25" Sq port length 1 18.25" Sq port length 2 16" Total port length 41.375" Sq port area 123.35 sq in Box volume 8.167 cu ft Tuned frequency 28.35 hz I'm sure most of you guys have seen the RE program I was using.... This one > http://www.reaudio.com/LPort_Box_Calc.php Only thing I'm not sure of, is whether it takes into account speaker displacement. I assume not, since they don't know what subs you will be using ? That's why I'm calling this box 8 cubes. But hey now, I have heard a million X's, and said so quite a few X's myself, that "the box is everything"...... But is it literally "everything" ? No differences between a 12" and an 18" with SQ ??? Hmmmm. Peace, Fish what it will play is based heavily on the box that its in. use the right box and it can play whatever music you want X2!!! It's all in the box man
shogen Posted August 3, 2011 Report Posted August 3, 2011 try using the Torres Calculator... See if those numbers generate the same results... I don't like RE for some reason, just doesn't seem right... Could be that I'm stoopid though... Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
Fish Chris Posted August 3, 2011 Author Report Posted August 3, 2011 Shogun, thank you. I will look up the Torres Calculator now. BTW though, have you ever seen, or heard of a port tuning nomogram ??? It's the actual graph that pretty much all of the modern box building programs are based on. Here's what it looks like: I could sit here and explain it, but you can probably figure it out on your own anyway. I print up several of these for every box build, then, even if I have used a modern PC program to design the box, I go back and check everything with my old school port tuning nomogram I already did this for the design above, which I ran in the RE program. Came out pretty much spot on Peace, Fish Edit: Okay, so I downloaded the Torres program.... That thing is freaking awesome ! Only thing was, inputting all of the same numbers, it shows my box being a net of only 7 cubes, rather than the 8 cubes the RE program shows This sucks, because if this is true, I don't think I can squeeze 8 full cubes into my available space Granted, it only brought my tuning up from 28hz, to 31hz.... But still, I want a low frequency monster ! Hmmmm. I think I will sit down tonight and calculate out my exact cubes long hand, with pen, paper, and calculator..... try using the Torres Calculator... See if those numbers generate the same results... I don't like RE for some reason, just doesn't seem right... Could be that I'm stoopid though...
