Ok guys. Referring to my "IHaveADream" build of Dual SMD 18s... I have an idea of using 2 18 inch PRs which would be mounted under (or over) the 18in subs. The PRs would be used instead of incorporating a port. I also like the idea for the WOW factor. The untrained eye/ear will think that there are 4 monstrous subwoofers. I have to do more research myself but what are your thoughts?
check out steves towers. he used smd's with 2 passive radiators per sub
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
Are your goals to get loud or just a "wow factor"?
I think a port would get louder.
And if you were going to do 4 subs, (2 working and 2 passive.) My not just get 4 working subs and be even louder?
90% of the people you meet wont have a clue what a passive radiator is and will just go "Wow it looks loud"
Big 3 with Yellow Top
ive always thought passive radiators were primarily for home theater use because the enclosure could be much smaller then the equivalently tuned ported enclosure. im not sure how this would work in a car. and generally you want twice the cone area for the passive radiator vs the subwoofer. so you would be looking at 2 pr's per sub.
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
no the enclosure needs to be the same size, but there are instances where you need to tune a fairly small enclosure fairly low, with a pretty big port, which won't fit in the enclosure.
the Peerless XLS 12inch subwoofer for example.
I'd put it in about 1.8cuft, tuned to 25Hz or lower, the problem is this means for a 4inch diameter port, it needs to be 28inches long.
