my tire size is 245/30/20
the nail is right in the middle of the tire, it got in there sometime last night, and i checked on it this morning and the tire is keeping air.
so should i get another tire?
leave it in there?
get a plug?
any input is appreciated, thanks
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
4 DC XL's W/ PSI Recones
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
Mechman 220a Alternator
leave it in there?
get a plug?
right in the middle? get it professionally plugged. as long as its right in the middle, should be no problem at all. but make sure they do it right (unmount the tire, grind down around the hole from the inside, and send a permanent plug through it)
Edited by mbdblue
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
well i wasnt sure if you could plug a 30 series tire
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
you kinda got lucky in a way, if nail is too close to the shoulder your F'ed
if its in the middle and the tire is not "run flat"(happens when u run it low on air) YOU CAN GET IT FIXED
the right way to do it is to dismount it, plug it and then patch over it. should last aslong as your tire will :)
id offer to fix it but kinda far away lol
plugging it should work fine
Edited by vettedude102
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
Just patched a 275/65/r17 about two weeks ago. Tire went on 05 yukon xl and the tire has tire pressure sensors in the valve stems. I took it to wal mart and for 10 dollars they removed the tire, ground down around the puncture to the steel braid, and patched the tire from the inside. It has held up under many tasks towing two zero turns, towing a carolina skiff, and heavy cornering loads. I will say my man phillip at wal mart has my loyalty in the tire department
- 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene
My Selling Feedback
Build Log
dont know about the walmart in your area but the ones here wont touch aftermarket wheels......noobs
pull the nail out a little bit at a time, put some water or spit on it . If you see air bubbles you need to get it fixed, if not you should be good.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
thanks for the input evrybody!
i feel much better about not having to lay down another $160 :drinks:
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
  • Who's Online   0 Members, 0 Anonymous, 647 Guests (See full list)
