Its too bad you arent near me. Id come over with this http://www.dremel.com/en-us/Tools/Pages/ToolDetail.aspx?pid=Multi-Max and use the baseboard cutting tool to slice that screw in half. It would kill my blade since its made for wood not metal but it would still cut the screw either way.
Another thing i thought of but i wouldnt do is to get something like a chisel and put it underneath the gasket of your sub and onto where the bolt is and get a hammer and wack at the screw enough to get it to break.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
There's no room for bolt cutters guys. The screw comes up MAYBE 1/8", probably less. I can hardly get a flathead screwdriver between the basket and box. I'll update what I try and what works (or doesn't) tomorrow.
SMD Super Seller
My Feedback Thread
I think that may be enough to get them to start a cut, then take vise grips and rock it back and forth...or try one of these.
http://www.harborfreight.com/oscillating-multifunction-power-tool-68303.html?ccdenc=eyJjb2RlIjoiOTM0ODg4NDkiLCJza3UiOiI2ODMwMyIsImlzIjoiMTkuOTkiLCJwcm9kdWN0X2lkIjoiODAyOCJ9
Surprising, they work quite well lol.
I've got the brand name version of this and I've used it for the exact reason the op needs. Its one of my most used tools. Mine has an extra knife blade attachment that I use to clean the surround and spider off when I do a recone. I can recone an 18 in about 20 min from start to finish.
^^^^^^^that would do it
Same thing happened to me the other day. What I did was grabbed one of my pry bars and pryed up on the sub, then it should put some pressure on the nut to be able to unscrew by hand.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
