3-way Comp Ohm load
I'm having no luck selling the Rainbows, so I might use them. Each channel of my 175.4 will have a set of 3 speakers on it, midbass, midrange, and tweeter. The midbass has its own crossover, and the mids/tweets share a crossover. Each individual speaker has a 4 ohm vc. Is there a way to figure out the ohm load to the amp without hooking everything up and getting a dmm reading? I'm still undecided whether to use them or not. Anyway here is a picture of how the manual shows to wire it up.
SMD Super Seller
My Feedback Thread
you can figure it out mathematically but you need to know all the details of the xover like the impedance of each of the components inside and the path the signal takes
such a headache for a 3 way
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
my first guess would be 2ohm but i really dont know... i had the midbass on its own channel when i did mine.
yes, you can run one set of speaker wires then split them at the crossovers.
if the xover is from the speaker set then the manual will tell you lol... other than that you will have to dmm them... but the xover i was messing with if i hooked a 4 ohm mid and a 4 ohm tweeter to them it was still 4 ohms not sure what would happen if i did 8 maybe ill try tomorrow
You will not get an accurate DMM reading through a crossover. Caps will look like an open circuit with DC applied, so DCR will be infinite.
If the crossovers are designed correctly so that the frequencies between the 3 drivers do not overlap, the amp will only "see" each driver within it's frequency range. This means they do not act like drivers in parallel.
Any frequencies that the crossovers allow over lap between drivers, the amp will see those two drivers in parallel.
If there are resistors in series with any drivers, it would affect the reaistance over the frequencies that driver plays. Coils in series will add some reaistance, but normally well below 1 ohm.
Current system:
Previous systems:
So, in plain English, are you saying its a waste of time to wire these together and put the dmm on them?
I'll be back in an hour or so.
SMD Super Seller
My Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 1568 Guests (See full list)
