Bad day in Ampville...
kalilac619
SO....6 power supply mosfets in My digital designs Z1a decided to take a shit on me yesterday.
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
Ouch at least their the cheap ones damn outputs are expensive
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
i overnight-ed it to Chris at dB-r and told him just to overhaul the whole amp and replace all Fets and anything else that's replaceable whether it needed it or not.
better to start fresh.
Cost me ~$290 to do my Z1 iirc..
Hammerdown... 1%
sounds like every single other z1 amp ive ever seen.
I thought the Z1a was suppose to be the better more powerful updated version of the Z1?
Yeah, the regular Z1s would blow at random. You could beat the piss out of them and they'd be fine and then pop shit at low volume. They had a lot of strange issues with the original Z1. The Z1a improved all the "unusual" problems the Z1 had. But the Z1a was not the most reliable amp either, they were much better amps but abusing them was never a good idea. Wire to 1 ohm, and keep the voltage up and they worked forever. Many abused them with luck, but a lot of them went pop wired under 1 ohm and voltage drop. Either way, very unfortunate OP. Get it fixed, and treat it nicely and I doubt it will give you any more problems. The Z1a is a great amp. My Z1 worked perfect when I got it, but I still had it repaired by DD for cheap before it blew (they cut me a deal for sending it in prior to failure). And when I got it back, it STILL had an issue. It thumbed when I turned it off, it was annoying but I was lucky enough it never blew on me. They make some power though!
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
  • Who's Online   0 Members, 0 Anonymous, 503 Guests (See full list)
