CJs F150- 8/10..1 9k??? Nope....2!!!!
So I know she's playing now...right? Where's our vids? :woot:
Only turned it up jsut enough to make sure everything is working properly. I still ahve to pull the subs back out to install the braces and put the final touches on the inside of the box. I will get that done and get the 4 channels setup tomorrow so I can have some music and crank it up.
I retuned the amp today to show the difference in tuning with the scope and having to visually see the clipping and the dd1 only having to see the distortion light come on.
Get some vids of it playing :drinks:
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
Looks good man, that box just looks small for 6 15's my 4 18's wall is all the way up to the front seat. I have no leg room. Let us know how it does may be pulling mine out if i can get some more room
2005 Lariat F-150
On 30 inch DUBS
6 Crossfire XS-V2 18's
2 Cactus 12k's, 1 Cactus 1000, 1 sundown 100.4
12 - 6.5 Crescendo mids and 4 Crescendo supertweets
SMD 340 alt, Mechman 270 alt
7 NSB 170 batterys
I've got right at 18ft3 after displacements which works out to 3ft3 per sub. 4 18s needs 22-24ft3 after displacements.
Im sure reading>me, but whats up with the 10" and 1.2k?
he said he is going to use the 10 and the 1.2k for daily driving around and when u really wants to slam he will use the wall
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
I have 16ft3 after disp on my 4xls 18s sounds great also. Weres those vids at :-)
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Fantastic build - love all the blue!!
I have the perfect idea for a non permanent method of filling the gap between the roof and the top of the box. Use fibreglass loft insulation, cheap as chips and when you stuff enough in it sounds like concrete!!
Daniel Brill-Edwards - Representing English Bassheads!!
Old Build Log - http://www.stevemeadedesigns.com/board/topic/94637-vw-golf-mk3-1996-build-from-england/
New build coming soon with SMD V1 #99
YouTube Channel - http://www.youtube.com/brilledwards
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
