Ok so Steve asked me to post the results I sent to him, Tony and Juan.
Basically in our shop for the past 6 years I have been taught to tune with a DMM to set amps. And since this is a common practice. We wanted to see how much different it was using the DD-1 in the same car with the same setup. One tuning method vs the other. So here ya go I have 2 cars we have done so far. I will post them separately. In both tests the cars were on a 15 amp charger during all testing phases. Enjoy!
Edited by Jville140db
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
First Test
The tunes on the amps were done as follows. The first tune was done with a DMM with the deck set @3/4 volume. You know the good old formula method. The second tune well that was clearly with the DD-1. So what we looked for was max spl on music at tuned volume. Maximum volume of tune. The last was temp of the amp after 15 mins of 3/4 volume of max volume based on tune. The amp used was an old 250.1 lighting audio bolt amp with 2 crunch 12's a stock dodge headunit with a single run of cca 4 ga and a cheap line output converter with no adjustment. So are results are as follows.
Tools used Smd DD-1, Craftsmen DMM, a digital inferred temp gauge and an epic 160 i know its not a TL but its just for comparison of overall SPL.
The vehicle is a 2004 dodge dakota extended cab with a sealed box and subs forward.
Spl was based in lower passenger side a pillar with the drive door open and all other doors sealed.
Base temp before any testing or playing 77.6F on both tests.
The first tune based on a headunit max volume of 38 we tuned to 28 roughly 3/4 volume.
We hit an Spl on music of 130 DB
after that we set the system to 3/4 volume of the max tuned which was 21 on the volume and let it play regular music for 15mins than measured the temp at the bottom heat sink of the amp which was 114.6F
So than we let the vehicle sit for 2 hour to let all the items cool and to let the the battery recharge. After which we retuned with the SMD DD-1.
So with the same criteria we set to work.
Well the head unit according to the DD-1 distorts at volume 21 so we backed it off to volume 20. Then proceeded with to tune the gain with the DD-1 which was now at 1/4 not 1/2 as it had been before with the DMM tune.
So then we tested max SPL with the same track as before at max undistorted volume which yielded a 134 on the meter. Thats a huge increase of course we were shocked.
Then we did the 15 min real world music test in which we set the volume at 3/4 well actually it was 16 out of 20 so 80% volume we ran the same tracks and at the end of the test the amp read a shocking 112.2F. So the amp ran cooler as well hmm.
so as I was checking voltage through out the 15 min test I noticed something with the dmm tune we would drop down to around 12-12.4 volts on most heavy bass tracks. After the DD-1 tuning it would fall between 12.5-13.2 most of the time being on the high end of that.
So to say the least the proof is in the pudding. The DD-1 does what it says it will and more. The amp ran more efficient. The subs were louder and on top of that the electrical didn't get nearly as taxed for the given output.
Currently in car
Second Test
Ok so here goes for the second SMD DD-1 official real world test.
So the Equipment and vehicle are as follows.
Vehicle was a 2008 Honda Pilot
Head Unit- KDC-BT948HD
Subwoofer- AudioBahn slim line AW1004J run @ 2 ohms
Speakers- Polk Audio Dxi6500 componants in the front and 650 Coaxials in the rear
Amps- SSL EV4-1600 and Polk PA880
Wiring and Electrical- Single Run of Kicker Z series 4ga batt to distrabution blocks and 8ga out from the disrabution blocks to the amps. Signal wires were Kicker X series and speaker wire was a combo of factory wire, kicker z series and install bay 9 wire.
Sub Enclousure- Sub was custom mounted in the factory sub location
Tools used
SMD DD-1
Craftsmen DMM
Inferred temp gauge
Epic160 for spl test I know its not a Termlab but it will show a difference in SPL for our purposes.
Ok so as before we used the same series of tests.
First tune was done with a DMM. We toook the headunits max volume of 35 and went to 3/4 of that which was 26. after that we tuned the amps using the good old ac volt forumla like in the previous test. Which gave us 14.4 volts @ 4 ohms on the 4 channel which should be 50watts. The mono was tuned at 24.5 @ 2 ohms as to not exceed the subs RMS of 300 watts. So after tuning was done the crossovers were set at 120hz @ 24db per octive and the sub amp at roughly 100hz @ 24db per octive and we ran our tests.
The max spl of the system on music was 112db.
The temp before tuning was 79.6 on the 4 channel and 81.6 on the monoblock.
After the 15 min music test @ 3/4 of max tune volume which was volume 20.
The temp was at 85.4 on the 4 channel and 101.4. on the monoblock.
So with this test I also recorded the starting voltage and the lowest voltage at any point during play of the 15 min test.
Which was 13.1 at the start and 12.5 at the lowest point during play.
So I also took note of where the gains were set on both tunes
The DMM tune was set at 1/3 on the 4 channel and at a little over 1/2 on the monoblock.
So after the DMM test we let the amps cool down and the battery recharge.
Than we went to work again with the SMD DD-1.
So in this test vs the last we found clipping through the amp instead of the Rca's like on the previous vehicle.
And we found that our max volume undistorted was at 33 out of 35.
So using the same battery of tests and the same music we set to find out what the DD-1 would bring to the table.
The max spl jumped up from 112db to 115db. on music.
The 15 min music test was up next so we set the radio @ 3/4 vol which was 25, and with the monoblock putting out more power I did expect a big jump in tempeture since the amp is rated @ 500 watts RMS and in the last tune we tuned to 300 watts RMS.
However the results of the heat test were rather shocking.
With starting temp this time of 80.6 on the 4 chan and 81.1 on the monoblock.
The 4 channel ran up to 85F which was a difference of 1.4F which was a lil cooler and the monoblock did run hotter as expected but it was only 102.2F thats a difference of 1.3F almost nothing given the amp was putting out more power in this test as seen by the spl result.
The voltage through out the test also revealed promising results at a starting voltage of 13.1 and the lowest at any given point was 12.8.
The gain setting moved as well in our favor as instead of 1/3 on the 4 chan we are now at 1/4 and on the monoblock we went from just over 1/2 to 1/3.
Currently in car
great review! thanks for taking the time to write all of that up!! :drinks:
Follow my Tweet (Twitter)
No prob bro more to come stay tuned
Currently in car
Very nice job bro! :drink40:
My POS Bass machine-
2003 Hyundai Santa Fe on some shitty 22's
Bed Liner Paint Job-Pioneer AVH 3200DVD
4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)
4 Arc Audio XDI2000.1 for the woofers
6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters
2 Arc Audio KS300.4's for mids and tweets
1 Arc Audio ALD 10v Line Driver
All Audiotechnix Power wire
1 DC Power 270XP High Output Alternator
1 XS Power D3400 up front....6 XS Power D3100's in the rear
Air Lift 1000 Bags in rear to help with suspension
If your still reading this GFY.......
Dude that is really awesome, I cannot wait to get one of the bad boys. My birthdays coming up on November 8th, going to try and get it from someone for my birthday.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Posts like this are why as soon as I have the money this tool will be in my arsenal. The only bad things people say about it are ones who dont use it. All the people who use it rave about it! Can't wait!
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
