BassMunky Posted September 3, 2011 Report Share Posted September 3, 2011 Anyone got any good tips on how to adjust them? How much of was your guys one from the factory settings? I tried to set it today and it was only .1 off from the factory. idk will try again tomorrow. i using a dmm,but would a fluke mm be better? i did the big 3 and have a die hard platinum battery with a stock 80 alt. It sits at 13.6. Im thinking something wrong right now. maybe too small wire cause only running 8 gauge for my amp that has 600watts. i am gonna upgrade to 0 gauge with my new setup. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
LoudBimmer Posted September 3, 2011 Report Share Posted September 3, 2011 why would you adjust volt meter? Link to comment Share on other sites More sharing options...
memphisBred Posted September 3, 2011 Report Share Posted September 3, 2011 You have to calibrate the stinger meter. That's why you adjust it. Or else it may read 12 volts when it's actually 14 volts at the batteries. SMD Super Seller/Buyer Audison----Hertz----Rainbow Link to comment Share on other sites More sharing options...
AMI CUSTOMS Posted September 4, 2011 Report Share Posted September 4, 2011 It is calibrated at the factory you normally won't have to adjust it, the last four I have installed were dead on to my fluke dmm. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty Link to comment Share on other sites More sharing options...
memphisBred Posted September 4, 2011 Report Share Posted September 4, 2011 The first one I had was off .3 volts. I kind of over did it with the 2 volt difference. SMD Super Seller/Buyer Audison----Hertz----Rainbow Link to comment Share on other sites More sharing options...
BassMunky Posted September 5, 2011 Author Report Share Posted September 5, 2011 do you think 0 gauge power wire will raise the volts? im running 8 gauge right now Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
blownengine Posted September 5, 2011 Report Share Posted September 5, 2011 why would you adjust volt meter? Because I always want to think my 12 volt system is really 18 volts. MOOAARR POOOWWWWAAAA! Haha 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free) Link to comment Share on other sites More sharing options...
Stephen Posted September 5, 2011 Report Share Posted September 5, 2011 stinger meter sucks for accuracy. I checked against a calibrated power supply at work FRESH from the cal lab. and you can adjust at say 14.5 volts and then drop the voltage to 12v and it will be off .2-.3 volts. power supply is accurate to 1/1000th of a volt and double checked it with an agilent 6.5 digit meter. you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER Link to comment Share on other sites More sharing options...
OrionStang Posted September 5, 2011 Report Share Posted September 5, 2011 I just installed a Stinger, had to calibrate it (.2 off). It is accurate at 14volts (idle) and 13volts (full tilt). Tested against my dmm. SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
armykyle1 Posted September 5, 2011 Report Share Posted September 5, 2011 my stinger volt meter was off by 2 volts and now I have to constantly adjust it. I've rewired it a few times. the mm you have should be pretty close imo... TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting Link to comment Share on other sites More sharing options...
