hello i have a 2001 tahoe, i have question or two. i am adding about 2400 lbs. of audio to it. i want to keep my balance on my truck so i can enjoy driving it. do i need rear air bags or stiffer springs? any advice will help. thanks.
Helper bag setup.
Spring isnt gonna hold it for long
  • 1 month later...
bags
Add a leaf should be fine. If not put 3in lift springs on it
Unless I'm mistaken (and I seriously, seriously doubt it) Tahoes/Yukons/Suburbans don't have leaves...
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
My 1999 Denali is Leaf Springs in the rear and Torsion Bars up front. You could stiffen the rear springs and drop the front to level out the ride. Adjusting ride height on torsion bars is stupid simple!
Edited for accuracy.
**Looks like 2001 is Coil spring in the rear.
Edited by Tarball
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
You would have to do a 2-3 in lift coil, but the ride will suffer a little.. your going with a stiffer spring that is compressed a lot which makes it even stiffer.. I would prolly lean towards a simple coil spacer..
Laying frame soon.. System has to wait
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
