Helper bag setup.
Spring isnt gonna hold it for long
  • 1 month later...
Add a leaf should be fine. If not put 3in lift springs on it
Unless I'm mistaken (and I seriously, seriously doubt it) Tahoes/Yukons/Suburbans don't have leaves...
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
My 1999 Denali is Leaf Springs in the rear and Torsion Bars up front. You could stiffen the rear springs and drop the front to level out the ride. Adjusting ride height on torsion bars is stupid simple!
Edited for accuracy.
**Looks like 2001 is Coil spring in the rear.
Edited by Tarball
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
