My doors get drowned out almost completely by my sub (lv5 18) and was wondering if there is a pair (singular) of 6.5s that can get loud enough to keep up. they will be going in stock location, only reason i dont want more than 1 pair is because i refuse to cut up on my door panels.
was thinking about These but not sure how loud they get. Will be run on 80-100rms at 4 ohms or about 150ish if ran at 2 ohms per channel.
and atm i have kicker ks60.2s which start to not like the power when the volume goes up around 25 on some songs(loose clarity and get harsh and distort, and my gains are set for 29.
Edited by ChevyBoy95
I really like my Image Dynamics CTX-6.5cs, They always kept up with my 2 XLs on the AQ3500, I was running them off about 80rms per side. But make sure you have room for the magnet cause they fat haha.
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
i have room for about 4.5in of depth and the mag can be as big as the hole, nothing is there to obstruct, ill look into those.
that's what I have in my car, running off a T400-4. Keeps up with my 2 level 4 12s really well.
they held up kinda to 2 level 4 15s i had, but not close for the lv5
Love the RF components, but will it be loud enough for you?
Power? Enclosure? Placement? Firing? And power to run the comps?
Do you refuse to cut the door panel due to inexperience or fear? If you drive a Chevy truck and the sub is directly behind you, you may be hard pressed to find something "loud" enough to truly keep up, especially assuming the budget you're looking in. Possibly look to some pro audio, maybe even crescendo
I'm confused, you already know they won't hold up but asked about them anyway? Or have I just totally missed something here.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
i thought you were referring to the kickers i had, i didnt think when i read your post, by bad.
power = 80-100watts if at 4 ohms, 150ish if at 2
enclosure would be the stock door location near the kick (deadened completely, i mean the door)
the tweets would be where the switches on the door are pointing at a 25ish degree angle towards the center, mids in stock location.
I dont want to cut it not because of fear or inexperience, but basically its my father, its my truck(but he has title and true ownership, im the listed driver or some ish) but if the time came to get a new vehicle and sell it, he wants it to be able to return to completely stock. everything i have done so far is reversible except deadener. The sub is firing up along with the port behind me yes. I may have to opt to kicks and run 2 sets. Just trying to keep it simple too.
BUDGET IS WHATEVER, IF THEY GET LOUD ILL SAVE UP FOR THEM, but right now probably 250-300ish or lower.
My Rockford T2652-s are in my kicks and sound good, but 15"Fi BTL is in the trunk and mine is not directly behind me. They still get loud.
2012 GMC SIerra CC
System Build
Headunit--Stock
Sub Amp--DC 2.0k
Subs--2-SA8v2's
Enclosure--Need one made!!
Highs Amp--Sundown SAX-100.4
Front Highs--Rockford Fosgate T2652-S
Rear--Sundown Neo Pro 6.5
XS Power D2400--XS D3400
No Big Three yet!
http://www.youtube.c...ser/raolito1980
