one of my friends just changed my 2 front break pads in my truck, he just did the front and when i break on the truck the peddle starts shaking and it breaks really funny after 3-5 min driving the abs light turns on and it breaks smoothly! i turn off the truck and same scenario all over again, i disconected all my batteries for about 30 min and connected everything again and still same shit! any suggestions on wat it can be?
05 Ford F150- STOLEN!!!!4 AA Havocs 15s in a WALL4 Hifonics 2006ds1 kinetik 1800 in front4 kinetik 2400s n bakHifonics MaxxlinkAudiocontrol Epicenter2 runs 1/0 guage kicker hyperflexall other wires r knukonceptzTraded In05 Chevy SilveradoAscendant Audio 16 12s2 Mechman 320s1 Kinetik 1800 in front8 Kinetik 2400s n back4 2200 Audioques ampsLots of 0 gaugePioneer DeckAudio Control preampHifonics Maxxlink
NOW
2012 Dodge Ram Hemi
4 Havoc 12s
2 AQ 2200s
2 Kinetik 2400s
Pioneer Deck
Audiocontrol Epicenter indash
All Rockford 1/0 & every cable in there
Jl audio xd 600/6
Rockford Fosgates Mids & highs
Built By Audiotistics!
Did he by some chance disconnect a speed sensor or "stretch" the sensor to where the wires may break inside? Did he just do pads or did he also do rotors as well
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
Sounds like your friend might have screwed up the ABS modulator when he was compressing the caliper pistons. If the ABS is screwed up, the regular brakes will still function normally, but I'd recommend taking it to a garage and have them check it out.
he either broke the wires to your abs sensors or broke a sensor. the sensors are mounted on the steering knuckle usually with an allen bolt holding it in place check the wires. but more then likely you will be replacing one of the sensors if not both. to solve your issue.
if your sensors check out then i would remove the caliper and check for leaks around the pistons (the rubber surround) if he tore the rubber compressing the pistons back into the calipers you could be getting break fluid on the rotors and your abs is trying to compensate for that. get it checked asap though and let us know
Edited by 01VWGREENMACHINE
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
might be a speed sensor like mentioned, my 00 jimmy does the same thing
not until i turn does it go off, it feels like in the winter time when the abs kicks in even tho the ground int even wet lol
*brake
You're an ass, Ray. LoL
As mentioned check the wheel speed sensors. Commonly broke item to people who don't pay attention to them.
Also, it's possible that he may have bled them wrong if that was done. ABS vehicles have a special bleeding procedure that is unique to each car.
If there's air in the lines still, your ABS system could be going nuts trying to compensate for it.
Was it a full brake job? Or just a pad swap?sounds like warped rotors too me...
2000 Suburban 6 runs of 2/0
12 timpano audio mids,6 timpana audio tweets and 1 timpano compression horn per door
8 banks of blue Maxwells + 260ah of Yin Long LTOs
2 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
161.6@38hz DBdrag  sealed on the dash… 162.54 outlaw…161.14 Meca headrest
Humm... did he bleed the brakes after he was done? The sensor is in the hub not the caliper like others said check the sensor wires, the abs modulator rarely goes out if the wire/connectors are fine bleed your brakes. Should be good to go
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
  • Who's Online   0 Members, 0 Anonymous, 470 Guests (See full list)
