i'm running 6 10's in a 6cube ported box in the trunk of a chrysler LHS. the trunk is a total of about 11-12ubes. box is ported through rear seat armrest. the problem i'm having is that when i play music there isn't as much bass as there should be, but when i open my trunk, i gain alot. i'm a noob so i'm not sure what could be causing this. could it be that there isn't enough airspace in the trunk for the 6 10's, or somethig else? i was running 2 15's in a 9cube ported through the armrest and it hit harder when the trunk was closed, that's why i'm not sure if the airspace is a problem. please help with this problem. thanks
you have cancellation.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i had this once. had to do with vortex theory
essentially with the trunk open the subs had more air to move and created a louder score. however this was because of a mistake of mine and it probably would have been louder if i had done the box correctly
show me how everything is setup in your trunk
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
sorry, i can't get pics right now, but the subs are 3 firing up and 3 firing back. i was just outside playing it, and a few of the subs were getting hot and a few were staying cool. what could cause that?
Having them like that is probably the reason, have them all facing the same way.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
out of phase?
might have to do with 3 firing up and 3 firing back (being in a trunk), thats prolly where your cancelation is coming from
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
so just rebuild my box for them to all fire up and that should fix my problem? does anyone think the airspace could cause another problem after i do that? asking cuz i know 6 10's moves more air than 2 15's
out of phase?
What's the specs on the box? As in port size and length. And box dimensions.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
You have around 11in^2 of port area per foot. You might want a little more if possible, but that shouldnt cause your problem that your having now.... Do you have a DMM?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
  • Who's Online   2 Members, 0 Anonymous, 9148 Guests (See full list)
