what is the smallest gauge a remote turn on can be?
Chevyboy aka curt bet me that my amp would not turn on using 30awg wire. and it did, and through 30ft of it. 30awg is almost like thick hair..
22 is plenty.
you can cook bacon shirtless if you're not a pussy...lol
not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be.
DC.jpgDC POWER
MOST amps draw about 0,3-0,5A for the turn on. 10001bd draws about 4A
i call BS, prove me wrong. ;)
DC.jpgDC POWER
well i think its some 18 gauge i got off of the old computer power supply. looks like it'll work100_0903.jpg
LMFAO!!!
if i still had it or my T500.2 i would measure it. i dont believe it though.
DC.jpgDC POWER
LMFAO!!!
About 8 years ago I installed a T10001bt that blew the remote out on 3 different radios (1 Alpine 2 kenwoods) in a day while tuning. I finally decided to check current draw and it was at 4 amps. Put it on a relay, done...never saw it again.
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
Sometimes if you have multiple amps it can draw a ton of current but a normal remote output will be fine for about 4-5 amps dependent on their current draw it takes to kick the amps internal relays on. I didnt clamp my remote wire because i really dont care what power it draws to turn on my amps and sound processor but it is running off 18 gauge wire with no problem. It is pure copper wire too. I had at one point 5 devices which needed to kick on when i powered my radio up. My 2 sub amps, my mids+high amp, my sound processor, and my radio bypass. It would handle all those turning on at once with just one remote wire off my radio. Sometimes like superjay said you do have to run a relay but luckily i have not run into that problem yet but if it does come up, they are super easy to fix and you can get a pre-wired mini spdt relay for like $10 and just wire it up and be done with it.
Either way the gauge wire doesnt make a huge difference, i personally wouldnt go any smaller than 18 gauge to help in case you happen to get an amp like superjay where it draws a lot of current to turn it on. You can always use speaker wire for the turn on. Im using 12ga speaker wire for my 3sixty.2's power and ground wires (overkill i know it but hey i had a crap ton of it sitting around). Also you can go to home depot or if you know a buddy or shop around online and get 14-12 gauge speaker wire in 100 foot rolls for like $15. As long as the wire is ofc (personal preference really, theres not a whole hell of a lot of current draw for just a remote wire in most cases) and has a decently thick jacket to protect the wire from shorting out im more than happy.
  • Who's Online   1 Member, 0 Anonymous, 481 Guests (See full list)
