Had a build on here before, but deciding to start fresh on a new log. Going 3 way active with the cda 9887 (trading my double din alpine for it), using a sundown 3000 on the sub stage (either btl's or Q's from Fi). Using also a sundown 125.2 for the mids, and a sundown 100.2 on the planars. For mids I am using some peerless 8's, and using Bohlender neo8 planar tweeters. Enough talking now ontop so pics.
Got the passenger side started yesterday, but have no pics of the process. But do have some of the drivers side
Here is the stock Drivers side kick
Taped it all up in blue painters tape
Next covered it up in aluminum foil
Then reinstalled the piece and put more aluminum foil down on top of the carpet and some brown painters paper on the edge
Dont want to get any resin on the carpet.
Mixed up some resin in small cups. Filled them up half way and put in hardener when I was ready to use that specific cup. Note, make sure you wear gloves on this part of the job, you will thankful that you did.
Yes I know its not the greatest resin in the world, but it will do.
Next I started to lay the fiberglass down. Using a 8sq foot pack of woven mat for the base right now. Cut that up into manageable pieces.
For the first layer I laid down a base of resin then laid the fiberglass on top of that and put more resin on the top so it soaked all the way through.
All three cups used so far, and a few more piece of glass to go. Using a halogen lamp right now to keep the area warm since its night out here now.
that is about 3 layers of glass in the corners and a 2 layers on the outer edges so far. Went out 3 or 4 inches farther than I have to. Easier to cut away then add on later.
formerly known as Blue86f150
this sux camel dicks
Well the bases are done going to let them cure for a few more days before I put some chop mat down on them. In the mean time, here are some pics of the finished bases and how the mids should be mounting on them.
The mids:
Peerless 8's
here are the bases
And an Idea of how the mids are going to mount on the bases
Drivers side
One of the passenger side
Tell me what you think so far. Plan is to eventually run 1 sundown 125.2 per mid
comments appreiciated
damn corona getting warm taking all those pics next to it.
good start
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
good start
If you notice it was still cold taking them pics. Lets just say, it was full for very long after wards. Got to keep my title going. :D
good start
If you notice it was still cold taking them pics. Lets just say, it wasnt full for very long after wards. Got to keep my title going. :D
Fixed it for ya
Lol, can't believe I missed that word.
Could alwase apply for that credit card that you got the application for... Max it out on corona and then have someone else do the work while you get drunk off your rear end ?
lol jk
Very nice start will definatly be watching this.
