DC Sound Lab
I had that problem with my re audio amp so I got a new American bass 4 ch and it did the same thing so I tested the crossover for my driver side tweeter and it was toast. also had it happen with my 6.5 kickers don't know what was wrong with it but when i unhooked that one speaker never happened again on that setup
Another reason i went full active..
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
How did you test the crossover?
multimeter on the caps and little diodes. caps where shot
Hi SMD Members If anybody has computer problems and is an SMD member with at least 150 posts I will fix your problems for free by phone support or I can also fix your computer over the internet.... I have references such as All State insurance, Nationwide Insurance and much more... just p.m me for help.. I am not the greatest with when it comes to audio systems so I figured I could contribute to the forum this way.... Thanks David
Well, I have 8 crossovers to check. Be back later.
SMD Super Seller
My Feedback Thread
Both of mine get warm but nOt hot. I am at 2 ohms per channel. Like had been said before, it is most likely in the crossovers. I am also running full active.
I had similar problems with my zapcos. But I'm wired at 10hm stereo on 1 and 2ohm on the other. Run the biggest power and ground wire the inputs will take. Like the others said it could be bad crossover check ohm load with system off. What components do you have?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I went and checked the ohm load at the amp with the system OFF, 4.2-4.4 on each channel. I also checked each channel with the system ON(don't know if that's the thing to do) and got some crazy readings. Checked the resistance at each crossover with the system OFF and all readings are good. So unless crossovers can be fucked up somehow and still read proper, its not them.
@98hoe; Rainbow 3-way components. SLC365.25NG
SMD Super Seller
My Feedback Thread
well now the fun begins. unhook each speaker meter seperately. hope you find a bad one. after that its unhook one speaker at a time and see what happens. if it stops cutting out you'll have found your issue. Wouldnt happen to have any different crossovers laying around.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I hope I find a bad one. There's 12 speakers to check, if I have to unhook 1 at a time......
SMD Super Seller
My Feedback Thread
highly doubt its a ground, ohm, or whatever issue, this dude knows what he is doing.... has to be in something being defective.., please report back what you find.....cheers and good luck....
I THINK I know what i'm doing lol. I hope its a single speaker and not the amp. If anyone can think of anything else to check, please post it.
SMD Super Seller
My Feedback Thread
