05 sunfire 18" rockford build
Sure is a pretty sub. The last two Robot Underground subs to come by me had the triple joints fail shortly after installing. One sub was a TC9 platform sub and the other was some blackeye pro thing. I helped the owner both times send them off to Dave at PSI for recones. It was a damn shame too, because RU uses some decent parts, it just looked poorly and lazily assembled. Hope you have better luck with yours, cause if it fails they won't fix it.
I actually made a sweet ass beer koozie out of the TC coil. :drink40:
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
9 cubes? in the backseat. might as well wall it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
9 cubes is just about right for that 18.. running the t1000.1 should be just right
general rule of thumb is 12 to 16" of port per cubic foot.. i generally stick with 14 to 15" per..
regualr pvc ports r a bad idea unless they r flared they have terrable port noise and offer minimal port area
that bracing looks to be cutting off air flow
R.I.P!
(Nov-29-2009)
92 explorer
current build
I think you'd be better off without that bracing. Or switch it to a 3/4 inch wooden dowl on both side of the sub. From front baffle to back.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
i think thats what im going to do in the morning before i do anything else :good:
