Hey, I recently brought a couple of 2 channel amps for my mid/highs and going to install a half decent front stage. I had my mids/tweeters wired to the HU so I asked my mate to cut them off and unroute the wired from the dash etc so I could run new cables to the boot. he decided to cut the ENTIRE BLOOODY stock wire harness!!
I'm rather pissed but hey I cant go back in time now. So I just finished soldering it all back together, everything works except for the dash/panel lights(fan speed/temp selector etc) aren't working any more. I don't have any loose cables in the space where they were cut yet its not working, I've checked the fuse and its allgoods.
Any ideas what it could be?! I'm still confused why the dash lights are going through the stereo wiring harness but who cares now. Any help would be appreciated. I will charge my camera up overnight and take pics tomorrow to help if you want them.
Cheers
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
I would recheck fuses, both in the car and under the hood.
Exactly.
There is a dimmer or illumination wire behind the radio (that dims the display) when the dash lights are on.
There has to be a blown fuse somewhere man.
Okay so I checked all my fuses ad non of ten are blown. Sooo? Any other ideas what it could be?
PSN: Rcp_soundz
My flat mate has a fuse tester thing. Put the fuse in and if the light goes then its fine. I also put two new fuses in and no luck then ether.
PSN: Rcp_soundz
Wats the vehicle
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
You nor your "mate" should be working on a car.
Take it to a pro before it gets worse
Sounds like an easy fix now as long as you know what your doing, which you clearly do not.
  • Who's Online   0 Members, 0 Anonymous, 1069 Guests (See full list)
