So, I've been a car audio enthusiast for about a year now, and have done several installs, but I am now in a bit of a pickle. I have recently purchased my very first pair of brand new woofers. Now, I went mainstream with my buy, but only because I got a good price for them. I bought two brand new Kicker 07' CVR 12's. Now, I bought some crappy Hitron 1400.2 amp off my friend for 25 bucks, and when hooked up to my CVR's, they sound OK, but I know they can take more and sound a lot better. They're in a ported box and have about 1.65 cubes per sub, (I know, I know, they need a little more, but hey, box was a good deal too.) And I'm now looking at amps to buy. I have minimal funds, and have pretty much narrowed it down to 2 amps. A Hifonics HFi 1000.1d, which runs 1000 watts at 1 ohm, (currently each sub is at a 2 ohm load), or a Quantum AQ 2000.D. I can get both amps for about the same price. The Hifonics is 150, and the Quantum is 165. The Quantum will push 1000 watts at 2 ohms. Help me choose please ! Or give me some suggestions for better amps in the 150-190 range. Thank youuu ! (:
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
I'm almost sure that neither of the Amos you mentioned do rated. You say you are wired to 2ohms right now which would mean that you have two dvc 2 ohms subwoofers. If that is that case you need to look for an amp that produces about 800-1000 watts at TWO ohms. Your subs (if dvc 2's) cannot present a 1ohm load so that power at 1ohm is typically cut in half at 2.
But I'll name a few Amps that do power at 2 ohms. Basically any kicker 1000watt monoblock, or alpine 1000, jl 1000/1, RF 1000 monoblocks. I actually saw 2 cvr's on a kenwood kac9105 and they sounded great, and that 9105 can be found pretty cheap on eBay. Basically all these amps are out of the given price range, but good deals can be found on them used.
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
Ap1500.1
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
you can get the kenwood 9104 for 179 new online usually. it does ok especially for the price. had one for a year with absolutely zero issues running 2 ohms on a kicker L7 12.
Alt - Singer 330A
Alt - Singer 330A
All those amps are waaaay out of my price range. And actually I have two dual 4 ohm voicecoils, wired down to 2 each. If I wired one of the subs to the other, and the 2nd one to the amp, that'd give me a 1 ohm load right ?
Alt - Singer 330A
thats correct it would give you a 1 ohm load if you wired it the right way....other wise a 4 ohm load
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
