PICS OF YOUR LATEST PURCHASE
I'll just leave this here....
You can order a set for a 1999 chevy tahoe 5.7L 4dr 4wd since your at it money bags. :P
It hurt when I submitted the payment. I almost cried, but it's something that I was going to need.
Team Bass-Hz
I was searching about brakes the other night about adding rear disc and upgrading everything in general.
I came across something that says they are not much better than the drums.
Something to do with the brake booster and the tiny valves or ports and more brake fluid needing to be sent to the rear to operate the calipers at 100% compared to the wheel cylinder.
They where also saying that if you want to have good brakes you need to swap over to the hydroboost setup off the diesels.
You can change the proportioning valve to get the proper fluid flow.
It would depend on what setup you went with as to how much of a difference it would be.
Its like every chevy site saying this about the rear disc conversions.
Also saying your better off upgrading the front brakes to something bigger and spending the money there long before the rears.
I dunno, just thought it was interesting.
my cheap[er] alternative to the intellicharger, does the same thing except i saved 140$... I still want an intellicharger though :lol:
But What Do I Know?
2003 Chevy Monte Carlo SS 3.8
  • JVC KD-R975BTS
  • Clarion EQS746
  • Kenwood P907PS
  • Ascendant Audio 12" Havoc v.1
  • Ampere Audio 2000.1
  • MB Quart Onyx 800.4
  • XS Power D3400 - Hood
  • XS Power D975 - Trunk
  • Singer 240A
  • Sky High OFC 0 & 4 gauge
  • Kno Knoise Kolossus Deadener
Nothing technically incorrect there. But...
Discs cool themselves better and don't fade like drums, but they are correct rears matter less than fronts. And they look better, if you're into that sort of thing...
If you do discs you should upgrade the master to match. Or prop valve like Broke said, but really a matching master is the way to go.
Hydroboost does create more line pressure, but so will an upgraded master cylinder. Brakes and hydraulics have come a long way in the last 20ish years.
The SSBC kit N8 is using comes with an upgraded master that matches their rear discs and has much better pressure and response for the fronts, as well.
My 96 Tahoe has some of the worst stock brakes of any vehicle I've ever owned. And I've owned a lot.
Static drops are my bag.
But What Do I Know?
  • JVC KD-R975BTS
  • Clarion EQS746
  • Kenwood P907PS
  • Singer 240A
sorry for the double...
But What Do I Know?
  • JVC KD-R975BTS
  • Clarion EQS746
  • Kenwood P907PS
  • Singer 240A
I tried to upgrade my master cylinder to a wilwood one but they said something about they don't make one because of the abs system.
Team Bass-Hz
