Checking your wiring and voltage and maybe phasing might be your easiest bet. Also can you move around your box to find other ways to 'load' the box?
Maybe it's just a wiring problem ?
Are you sure you have a 1 Ohm load ?
Check your wiring twice. This amp should really be enough for your sub. You don't need another one;
I've triple checked it, it's definitely loaded at 1 ohm. Now I realize 1700 clean un-clipped watts should
be enough power for the FI, but I just don't think the Hifonics is putting out anywhere near that with the
gain dialed in with the DMM to send out the clean signal.
What about crescendo? Last I knew BC 2k was about $340ish and did rated at 13.8V, so does a little bit more at 14.4V.
Yeah I would go with the BC2000. 340 shipped. heard lots of good things about it
Most likely, I'm going to return the Hifonics, and drop the 340$ on the Crescendo.
The BC2000D seems like a very high quality amp for the price and will probably put
out a little more than rated.
The only problem is, I have my JL Audio 2 Ga. amp kit already hooked up, will it be
okay for the amp? I also plan to do the big three in a few weeks along with a higher power battery (under the hood).
I have an AQ 2200d if you would like. I could get you out under 400 easily shipped
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Everybody I went ahead and bought an AQ2200D yesterday. With the Black Friday deal, the final price was 380$, just couldn't turn down that offer.
Now I understand pushing 2200 watts to FI BL is quite a bit, but I will rarely have it up all the way, and won't even think to touch
the bass boost.
Since I'm doing the BIG 3 and upgrading to a bigger battery, my only concern is will my JL Audio 2 ga. Amp kit be enough for the AQ2200?
No it will not be enough, you need 1/0 to really push that amp. I understand if 2 ga is temporarily, but i would only but 1/0 to it.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Or a second run 2 gauge.
"in the abundance of water, the fool is thirsty" Bob Marley
sone of em can be bought used for a LOT cheaper than the original price....
try that
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
Just wow at this thread. I don't believe the amp was the issue, the error was in the install or settings. So a new amp may not alleviate the issue.
I would like to know amp settings, voicecoil configuration, wiring, and headunit settings and spec.
