Two MD 15's reconed by FI
i have two md 15's and i purposly blew them both so i can get them reconed by FI. lucky for me FI is here in Vegas. I know its a knock off thing to do. but i bought these subs before i learned anything about fi. and i found out that MD stole a lot of FI's ideas. therefore FI is able to work on my motors because they are almost the exact same question. they are putting 2ohm coils on them. my question is what is the BEST way to wire them up and get the most power out of my amp without blowing my coils out again?
set your amp gain properly and you wont have to worry about blowing anything
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
If you're blowing them up, don't wire them lower than 2 ohms. Wire at .5 and you'll probably blow both subs and the amp.
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
if they havent been reconed already you could get dual 4 to get a 1 ohm load..but if they have possible get 2 of the same amp and strap them and wire to 2 ohms
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
You're high as a kite if you think that they are almost the same thing. FI can recone them because they have an inhouse mad scientist and know what will fit.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i originally had them wired at .5 but i just found a wiring diagram to wire 2ohm load to a 1ohm load. is that even possible?
No. Not into 1 channel anyways. Two dual 2's can wire to .5-, 2- or 8-ohms. If you ran two separate amps you could run each sub at 1-ohm.
Sub Amp: AB 450.1
XS D3100
Come on 150!
What ampare you running ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
its an md SW8001D supposed to be rated at 2500rms
  • Who's Online   1 Member, 0 Anonymous, 2243 Guests (See full list)
