what batteries? you might just not have enough electrical as far as batteries.
1 duralast gold 1000 CA 750CCA and 90 AH under the hood and 2 marine/generator batterys they normally used for campers they weigh 110 pounds each 1550 CA or CCA i dont remember and 180 amp hours each. what i wanna know is if 0 gauge wire can only allow 150 amps through it am i only get 150 amps out of my 270 amp alternator, that if i add another run will i get the full 270 amps?
the answer is no. 4800 watts = 480amps, you have 270 amps, your always going to have voltage drop unless you have more supply than demand, also most 0/ gauge will handle 270 to 350 amps depending on strand count .and most will say 1000 watts =100 amps . hope this helps
Edited by Bmike
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
  • Who's Online   0 Members, 0 Anonymous, 730 Guests (See full list)
