Vaccum sealed box?
Nobody vacuum seals boxes; that would pull the woofers' motors into the gap. Done properly, boxes are air tight though and will wheeze a little when the subs are pressed in slowly.
^ this is what i was wondering. So noone ever does it. Thanks haha.
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
what? that could be interesting to try up in space?
There is no sound in space.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
the foam surround on a sub is porse and will leak air and if ts a rubber surround and you did vacume seal a box it would suck the cone down and keep it stuck there like haveing your hand push the cone down then play it... it wouldnt work
the same as in free-air, make the cone move forward and backwards, although slightly easier due to less atmospheric content.
Hammerdown... 1%
this is going in my sig!
More box builds
I'm with captain stupid.
I can honestly say that's the first I've heard of a vaccum sealed box lol. I wouldn't try it though. Unless I had the time/money/boredness
1992 Camry "Stormtrooper"Quantum Audio DVD/USB/AUX 3.5" single din H/UXS D690Cadence 0g wiring and Kicker 4g wiring(2) Selenium 6w4p's(2) Selenium ST200'sKicker 200.4 (mids & highs)(1)Kicker and (2)Stinger RCA'sSecondSkin in trunk and doors12K HIDsMulitcolor Angel EyesSoon to be done:Big 3Mechman H/O Altsubs?amp?
That thing is going to eat people nearby cars, unsecured objects, and small children
Fixed!
wow nice. i wanted nos on my car but the gf said no. i was just gunna do a 50 shot tho haha
Get a new girlfriend.
  • Who's Online   2 Members, 0 Anonymous, 633 Guests (See full list)
